Visual LISP, AutoLISP and General Customization
Enhanced Attribute editor doesn't display on double-click
3 REPLIES 3
soatley99
898 Views, 3 Replies
i've searched a few things on the site, ie. attdia, dblclkedt, etc.---they all seem correct.
The odd thing is, the window just doesn't show up.  Info can be input, and I can tab through the lines of the editor.  It's as if the editor is invisible or is set to display in the background behind the drawing.
Any suggestions?
3 REPLIES 3
lpseifert
in reply to: soatley99
Maybe it's off-screen. While the command is active (and you think it should be displayed)...
Hit Alt+Spacebar
Hit M (for move)
use the arrow keys to move it back on screen
or
Hit Alt+Spacebar
Hit S (for size)
use the arrow keys to resize so you can see it on screen
you may want to try (practice) this with a dialog box that is visible so you can see what's going on
~~~Civil 3D 2008~~~
SomeBuddy
Do you have enough graphic resources ? Not too many applications rinning and draining your grphic card juice ? If you think it's not about this, maybe if you try to repare the install or maybe reinstall the application ?
soatley99
in reply to: lpseifert
Yep, that was the issue.  As I hit alt-spacebar, the icon went immediately to the left extent of the screen.  I tried it a few times w/ the mouse drag.  Then re-read your answer and used the arrow keys.......eventually the editor came back into the screen.
Thanks for the help, lpseifert
”Boost
