i've searched a few things on the site, ie. attdia, dblclkedt, etc.---they all seem correct.
The odd thing is, the window just doesn't show up. Info can be input, and I can tab through the lines of the editor. It's as if the editor is invisible or is set to display in the background behind the drawing.
Any suggestions?
Solved by lpseifert. Go to Solution.
Maybe it's off-screen. While the command is active (and you think it should be displayed)...
Hit Alt+Spacebar
Hit M (for move)
use the arrow keys to move it back on screen
or
Hit Alt+Spacebar
Hit S (for size)
use the arrow keys to resize so you can see it on screen
you may want to try (practice) this with a dialog box that is visible so you can see what's going on
Do you have enough graphic resources ? Not too many applications rinning and draining your grphic card juice ? If you think it's not about this, maybe if you try to repare the install or maybe reinstall the application ?
