Is there any option to enable Shaded viewport options in Model?
An costomer have many files probobly convertet to dwg from other software.
We have an LISP batch plot function that checks if the drawing is an model or layout and sends the approtiate answers to plot command.
When model behave as an layout the batch plot stops working.
Is it possible to check with lisp if model have "Shaded viewport options" enabled or force ti to be enabled?
Included:
svo_enabled.dwg - Shade viewport options enabled in model.
svo_disabled.dwg - Shade viewport options disabled in model.
/Micke
MODEL and SHADEMODE don’t change anything.
Both files are in Model and SHADEMODE is 2Dwireframe but they behave different.
Svo_disabeled.dwg have "Shaded viewport options" disabled and "Scale lineweights" enabled in plot dialogue.
I need a way to force it to be the same or a way to check the difference.
The part of my lisp that dont work when Model behave as Layout is:
(if (= (getvar "CTAB") "Model") (command "plot" "Y" "" pc3 (caddr (cdr (assoc ram papper))) "M" (if (or (= ram "A4") (= ram "A1S"))"P" "L") "N" "W" "none" ins "none" (list (+ (car ins) (* maxx skala)) (+ (cadr ins)(* maxy skala))) (/ 1 skala) "CENTER" "y" ctb (if (or (= ram "A1")(= ram "A1S")(= ram "A0")) "n" "Y") "A" fnamn "N" "Y") (command "plot" "Y" "" pc3 (caddr (cdr (assoc ram papper))) "M" (if (or (= ram "A4") (= ram "A1S"))"P" "L") "N" "W" "none" ins "none" (list (+ (car ins) (* maxx skala)) (+ (cadr ins)(* maxy skala))) (/ 1 skala) "CENTER" "y" ctb (if (or (= ram "A1")(= ram "A1S")(= ram "A0")) "n" "Y") "N" "N" "N" fnamn "N" "Y") )
The code stops at "A" when Model behaves as Layout.
/Micke
