Showing results forย
Showย ย onlyย  | Search instead forย
Did you mean:ย
Emoticon/Smiley-to-AutoLISP Translator
22 REPLIES 22
Message 1 of 23
Kent1Cooper
5495 Views, 22 Replies
Do you see Emoticons [Smileys, etc.] embedded in AutoLisp code in this forum?
If you are Signed In, and go to
My Settings / Preferences / Display / Emoticon type
and check the button for "None", you should then not see them when you are Signed In, but you will probably still see them when you get on the website but are Signed Out.
They are caused by colons being followed immediately by certain triggering characters.  Since this is a valid occurrence in AutoLisp code, they sometimes appear there.  Unfortunately, copying content that contains them and pasting it into a plain-text editor such as Notepad does not restore the original colon-and-character combination, but omits it.
So here's a Translator, so that you can tell what characters should go in place of the different kinds of emoticons.  It lists all combinations of a colon with any other character [on my US English PC keyboard].  Many of them do not trigger emoticons, but I am leaving them all in, so that if the collection of triggering characters should change, the translator will be up-to-date at the time anyone looks at it.
If AutoDesk should choose to remove emoticon capability from this forum as I would suggest, then this Translator will be obsolete.
[Remember, if you are Signed In and have your Emoticon type set to "None," this should not show any emoticons, but will be a rather pointless-looking list.]
:a = colon followed by a
:A = colon followed by A
๐Ÿ˜› = colon followed by b
:B = colon followed by B
:c = colon followed by c
:C = colon followed by C
:d = colon followed by d
๐Ÿ˜„ = colon followed by D
:e = colon followed by e
:E = colon followed by E
:f = colon followed by f
:F = colon followed by F
:g = colon followed by g
:G = colon followed by G
:h = colon followed by h
:H = colon followed by H
:i = colon followed by i
:I = colon followed by I
:j = colon followed by j
:J = colon followed by J
:k = colon followed by k
:K = colon followed by K
:l = colon followed by l
:L = colon followed by L
:m = colon followed by m
:M = colon followed by M
:n = colon followed by n
:N = colon followed by N
๐Ÿ˜ฎ = colon followed by o
๐Ÿ˜ฎ = colon followed by O
๐Ÿ˜› = colon followed by p
๐Ÿ˜› = colon followed by P
:q = colon followed by q
:Q = colon followed by Q
:r = colon followed by r
:R = colon followed by R
:s = colon followed by s
:S = colon followed by S
:t = colon followed by t
:T = colon followed by T
:u = colon followed by u
:U = colon followed by U
:v = colon followed by v
:V = colon followed by V
:w = colon followed by w
:W = colon followed by W
:x = colon followed by x
:X = colon followed by X
:y = colon followed by y
:Y = colon followed by Y
:z = colon followed by z
:Z = colon followed by Z
:0 = colon followed by 0
:1 = colon followed by 1
:2 = colon followed by 2
:3 = colon followed by 3
:4 = colon followed by 4
:5 = colon followed by 5
:6 = colon followed by 6
:7 = colon followed by 7
:8 = colon followed by 8
:9 = colon followed by 9
:` = colon followed by `
:~ = colon followed by ~
:! = colon followed by !
:@ = colon followed by @
:# = colon followed by #
:$ = colon followed by $
:% = colon followed by %
:^ = colon followed by ^
:& = colon followed by &
๐Ÿ˜˜ = colon followed by *
๐Ÿ˜ž = colon followed by (
๐Ÿ™‚ = colon followed by )
:- = colon followed by -
:_ = colon followed by _
:= = colon followed by =
:+ = colon followed by +
:[ = colon followed by [
:{ = colon followed by {
:] = colon followed by ]
:} = colon followed by }
๐Ÿ˜• = colon followed by \
๐Ÿ˜ = colon followed by |
:; = colon followed by ;
:: = colon followed by :
:' = colon followed by '
:" = colon followed by "
:, = colon followed by ,
:< = colon followed by <
:. = colon followed by .
๐Ÿ˜† = colon followed by >
๐Ÿ˜• = colon followed by /
:? = colon followed by ?
:  = colon followed by space
Kent Cooper, AIA
Tags (1)
22 REPLIES 22
Message 2 of 23
in reply to: Kent1Cooper
As I said in my last reply on the menu from LISP thread, maybe the right place for your AutoDesk request in order to remove these smileys is in the  Updates to Autodesk Discussion Groups thread, where it might have a chance to be seen by Eric Wright.
Message 3 of 23
Kent1Cooper
@Anonymous wrote:
....maybe the right place for your AutoDesk request in order to remove these smileys is in the  Updates to Autodesk Discussion Groups thread....
Done.
Kent Cooper, AIA
Message 4 of 23
Let's cross fingers and hope ๐Ÿ™‚
Message 5 of 23
rkmcswain
vBulletin and most other forum platforms let you disable smilies on a per-post basis.....
Message 6 of 23
Alfred.NESWADBA
in reply to: rkmcswain
If you use the "Insert Code" button then there are no smilies like this:
(defun C:DONTUSEDCMD()(command "_HELP"))
instead of this (without the "Insert Code")
(defun C:DONTUSEDCMD() (command "_HELP")
- alfred -
PS: sorry for multiple edits ๐Ÿ˜‰
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at ... blog.hollaus.at ... CDay 2024
(not an Autodesk consultant)
Message 7 of 23
@Alfred.NESWADBA wrote:
If you use the "Insert Code" button then there are no smilies ....
[That may be true now, but was not at the time of the original post.  I have a variety of reasons to dislike code windows, discussed elsewhere, so I don't usually use them.  But some of those may also have changed, and I recently find a new aggravating issue with not using them, that wasn't the case before -- code Ctrl+C-copied out of Notepad and pasted into the "body" of a Post here loses all indentations, but doesn't if pasted into a code window -- so I may start to use them more often.]
Kent Cooper, AIA
Message 8 of 23
Kent1Cooper
and check the button for "None", you should then not see them when you are Signed In, ....
If you're finding this years later, you're now [writing in Nov. 2020, but it's been a while] out of luck.  That choice has been eliminated.  Bad....
Kent Cooper, AIA
Message 9 of 23
marko_ribar
@Kent1Cooper
Have you seen this topic, and my report :
https://forums.autodesk.com/t5/community-feedback/lisp-was-added-to-the-forum-s-code-snippet-unlocke...
It seems that no one is able to disable this feature and BTW. I don't know how @CodeDing created that code tag without loosing info...
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 10 of 23
devitg
in reply to: marko_ribar
hI @Kent1Cooper , which letter combination belong to
:smiling_face_with_sunglasses:
as per
from
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/sharing-my-matrix-and-fractions-libr...
Message 11 of 23
Kent1Cooper
in reply to: devitg
@devitg wrote:
.... which letter combination belong to
โ€Œโ€Œ
It's an 8 followed by a right parenthesis.  I opened the file attached there to find out.  [EDIT:  Interesting -- the smiley description part in the code window did not survive being quoted from Message 10.]
Kent Cooper, AIA
Message 12 of 23
rkmcswain
Another way to bypass this, if you are the author, is to use the <PRE> tags
(defun C:foo ()
  (* (- (+ 3 8) 18) 38)
Message 13 of 23
marko_ribar
I have to test it...
[pre]
๐Ÿ˜Ž
[/pre]
I just typed [ pre ], than in next line ๐Ÿ˜Ž and last line [ / pre ]... pre signs are typed without spaces...
Message 14 of 23
marko_ribar
It didn't work with [] brackets, now with <>...
<pre>
๐Ÿ˜Ž
</pre>
Message 15 of 23
marko_ribar
Now I'll use code tags with <pre> before and after...
<pre>
8)
</pre>
Message 16 of 23
marko_ribar
Well I don't know...
Now I won't do anything, just code tags... Seems that it's working now...
 ๐Ÿ˜Ž
Yes I added one space before and used General tags...
Message 17 of 23
marko_ribar
No it's not working...
Can you elaborate more @rkmcswain that with <pre> tags?
Message 18 of 23
rkmcswain
@marko_ribar  - the PRE tags are HTML code. You have to be in the HTML editor.
(defun c:foo ()
  (- (+ 66 38) 18)
Message 19 of 23
rkmcswain
But of course if you have the graphical editor enabled, it's so much easier to just click the CODE button, and paste your code in. The effect is the same.
(defun c:foo ()
  (- (+ 66 38) 18)
Message 20 of 23
marko_ribar
OK. One more test for me...
8)
So this button is the trick...
โ€Boost
