Visual LISP, AutoLISP and General Customization
Editing Anonymous Blocks
10 REPLIES 10
Message 1 of 11
m_rogoff
1737 Views, 10 Replies
I have a DWG (attached) with anonymous blocks. The names are "U1", "U2", etc. I cannot go into block editor without specifying the name. The text inside the block had the color manually changed. I want to change the color (or layer) of the text inside the block. The actual drawing I need to edit has 100's of these ****ing things.
How can I change them quickly and uniformly? Thanks for your help!
10 REPLIES 10
Message 2 of 11
braudpat
in reply to: m_rogoff
Hello from France
This routine UNANON does the job but one block by one block !
http://www.draftsperson.net/index.php?title=Anonymous_Blocks_in_AutoCAD
Sorry I have not a multiple block routine !?
If you find one, I am ready to use it !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 11
pbejse
(defun tolayer (lay)
  (if (tblsearch "layer" lay)
    (vlax-for b	(vla-get-blocks
		  (vla-get-activedocument (vlax-get-acad-object))
      (if (and (eq (vla-get-ObjectName b) "AcDbBlockTableRecord")
	       (wcmatch (Vla-get-name b) "`*U*")
	(vlax-for o b
	  (if (and (vlax-write-enabled-p o)
		   (eq (vla-get-objectname o) "AcDbMText")
	    (progn
	      (vla-put-layer o lay)
	      (vla-put-color o acByLayer)
    (princ "\n<<Layer Does not Exist>>")
  (vla-regen (vla-get-activedocument (vlax-get-acad-object))
	     acActiveViewport
  (princ)
(vl-load-com) (princ)
 HTH
Message 4 of 11
3wood
SETBYLAYER command?
Message 5 of 11
in reply to: braudpat
It looks like that UNANON routine has an additional routine to process all of the anonymous blocks. Try UNANONALL.
Message 6 of 11
braudpat
Hello
I am a STUPID boy because I have not seen the UNANONALL command
which immediately "convert" the 7 *U blocks of the OP to 7 named blocks (TEMP1-TEMP7) !!
I have always use this routine for ONE Block !?
Congratulations and Kudos for you !
Patrice BRAUD
Message 7 of 11
Pat,
With some drawings, that must have been painful. Good luck with your new knowledge. 😉
And thanks.
Message 8 of 11
braudpat
Hello from France
YES I know that we have to be very careful with some anonymous Blocks !
Thks
Patrice BRAUD
Message 9 of 11
in reply to: 3wood
SETBYLAYER is the easiest, and gets the results I am looking for.
Thanks all for your input
Message 10 of 11
in reply to: pbejse
pbejse, where do I specify the layer in your routine? Thanks
Message 11 of 11
Shneuph
run it like this.
Command: (tolayer "Layername")
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
”Boost
