Any chance that all of those text-type objects are color BYLAYER on (a)
separate text layer(s), and you could just change the color of the layer(s)?
That would fix the ones inside blocks, too.
Kent Cooper, AIA
"GoodJuJu" wrote in message
news:32956523.1107782885140.JavaMail.jive@jiveforum2.autodesk.com...
> Is there a way using Lisp to convert ALL text to be color 7 within a
> drawing?
> I can change Mtext, Text, ArcAlignedText, Dimension Text and Attributes
> using
> (Defun C:TxtCol)
> (setq ALLTEXT (ssget "X" '((0 . "*TEXT,DIMENSION,ATTDEF,DIMENSION"))))
> (Command "Change" ALLTEXT "" "P" "C" "7" "")
> However, when it comes to blocks in the drawing I need to change the color
> of text and attributes inside the block without exploding it.
> Looking through other posts here, it appears that I need to search blocks
> for -2 codes.
> Any help is much appreciated.
