I used to use Bill Gilliss's excellent m2s.lsp to convert meshes (terrain) to solids. It would take every facet of a mesh and extrude it down to a comon base. Now, I haven't done this for a long time but I get the sense that this is no longer SOP.
What should I be doing instead?
I'm using AutoCAD 2012
Solved by strawberry12. Go to Solution.
Ah, as Bill G explains in the latest version of his lisp (http://www.realerthanreal.com/autolisp/m2s.lsp)...
"Set MESHTYPE to 0 to create old-style polygon meshes."
All OK now
