Visual LISP, AutoLISP and General Customization
eattedit for muliple block selection
3 REPLIES 3
566 Views, 3 Replies
I would like to change the color of one text attribute in many point blocks
at the same time, so it is not defined "bylayer".
It would be great if command "eattedit" worked for multiple block selection.
But it lets me do that only for one point block at a time.
Any help will be appreciated.
Przemek
3 REPLIES 3
Try attached lisp.
You (could) hardcode the blockname / tagname / color
if desired.
Bob
Thanks, Bob it works very good!
I wanted to differentiate between 2 groups of point blocks with
point/desc/elev tags on the screen.
Does color option BYLAYER have a color number assigned to it, if I wanted to
revert to original point block settings?
Przemek
wrote in message news:5784254@discussion.autodesk.com...
Try attached lisp.
if desired.
Bob
I have just found that Bylayer is 256, and Byblock is 0, thanks, great help.
Przemek
Try attached lisp.
if desired.
Bob
”Boost
