Show only
Search instead for
I would like to change the color of one text attribute in many point blocks
at the same time, so it is not defined "bylayer".
It would be great if command "eattedit" worked for multiple block selection.
But it lets me do that only for one point block at a time.
Any help will be appreciated.
Thanks, Bob it works very good!
I wanted to differentiate between 2 groups of point blocks with
point/desc/elev tags on the screen.
Does color option BYLAYER have a color number assigned to it, if I wanted to
revert to original point block settings?
Przemek
wrote in message news:5784254@discussion.autodesk.com...
Try attached lisp.
You (could) hardcode the blockname / tagname / color
if desired.
