Visual LISP, AutoLISP and General Customization
E-Transmit zip File name with current date
12 REPLIES 12
Message 1 of 13
danglar
603 Views, 12 Replies
How can I do it? I wont to receive something like this after  e-transmit command invoked
"dwgname-curent date.zip"
example: building-16.11.14.zip
12 REPLIES 12
Message 2 of 13
hmsilva
in reply to: danglar
If I understood correctly, perhaps something like this:
(vl-load-com)
(defun c:demo (/ a)
  (setq file (strcat (getvar 'DWGPREFIX)
                     (vl-filename-base (getvar 'DWGNAME))
                     (menucmd "m=$(edtime,0,dd.mo.yy)")
  (command "_.etransmit" "_c" file)
  (princ)
Hope that helps
Henrique
Message 3 of 13
danglar
in reply to: hmsilva
thank you! It work awesome but etransmit created in curent folder.. if is it posible how can i specify transmital folder
Message 4 of 13
hmsilva
You're welcome.
If hard coded, change
(getvar 'DWGPREFIX)
to
"YourDrive:\\Your\\Transmital\\Folder\\"
If not hard coded, say something.
Henrique
Message 5 of 13
danglar
it work exelent but you have one case when programm stoped. In case when your dwg not saved yet. I make a litle change in your code in order to fix this problem.
vl-load-com)
(defun c:demo (/ a)
(command "save" "" "Y")
(setq file (strcat "C:\\0backup\\"
(command "-etransmit" "_c" file)
(princ)
Message 6 of 13
hmsilva
What do you mean by 'dwg not saved yet', a new dwg, or a dwg already saved with a specific file name?
Henrique
Message 7 of 13
danglar
I mean if you not save your dwg before invoke regular etransmit function you are prompted to do it.. in opposite case you have not any problem with lisp
Message 8 of 13
hmsilva
Perhaps
(vl-load-com)
(defun c:demo (/ file)
(command "_.qsave")
(princ)
Henrique
Message 9 of 13
danglar
Probably this code is more elegant?
(vl-load-com)
(defun c:et (/ a)
(command "_.qsave")
(princ)
(c:et)
Message 10 of 13
hmsilva
Probably...
Don't forget to localize the variable 'file' and remove the 'a' variable (I did)...
Henrique
Message 11 of 13
danglar
already done. Thank you Henrique.
Message 12 of 13
hmsilva
You're welcome.
Glad I could help.
Henrique
Message 13 of 13
igal1971
small change ikn order to add more accuracy:
(vl-load-com)
(defun c:et (/ a)
(command "_.qsave")
(setq file (strcat "C:\\Your Storage Folder\\"
(menucmd "m=$(edtime,0,dd.mo.yy-H.MM)")
(princ)
(c:et)
”Boost
