E-Transmit Command
1 REPLY 1
bkp
283 Views, 1 Reply
E-Transmit Command
If we email someone after applying etransmit or copy that folder, is it possible that my lisp files can also get transmitted/ emailed along in that dwg file?
http://docs.autodesk.com/ACD/2013/ENU/index.html?url=files/GUID-5269529D-A013-4AB4-AAB7-DBA1C7CA73EB...
This link says it includes all related dependent files such as xrefs and font files.
I am not clear of the use of this function/command.
So need some detailed explanation.
Bhaumik
1 REPLY 1
hmsilva
in reply to: bkp
Bhaumik,
no!
The "etransmit" command, will includes the font files, ctb or stb files, pc3 files, External references (dwg's, images, dgn's, pdf's  and dwf's), textures from materials, files from data links, photometric web files (lights)...
HTH
Henrique
”Boost
