"Mark Propst" ha scritto nel messaggio
news:D2735250E23D3E6F6284F458184A5E0B@in.WebX.maYIadrTaRb...
> "Giampiero Dattilo" wrote in message
> news:CBB2BE9E9ECD3881B6BDA7CFCA825003@in.WebX.maYIadrTaRb...
> > "Warren Trost" ha scritto nel messaggio
> > news:5AC9ACC79A3A7E378F5E8991735FFDB2@in.WebX.maYIadrTaRb...
> > > In the help menu? Should have full info.
> > In the help menu not is specified many things, e.g:
> > 1) what section are indispensable?
> dont know what you mean, depending on your object there would be a logical
> minimum of information you'd need to provide if you were creating one,
like
> for a line, startpoint and endpoint, a circle, center and radius etc, any
> elements not specified will take on default properties like current layer,
> linetype etc, unless you want to specify them as well, is that what you're
> talking about?
> > 2) what is a Dictionary, a Reactor, a Class?
> nothing in the help really? I entered "Dictionary" in the search field of
> the help (developer help) and instantly got 148 topics.
> class yielded 163 topics
> reactor 143
> > 3) why for each block there is a block_record? what is a relation about
> this
> > things?
> well, that's what a block is, a record of objects which, when combined,
make
> up a grouping which you can deal with as a unit, and which can have a name
> and other handy properties, and of which instances can be created (block
> references) such that all instances will share the common properties
listed
> in the block record.
> do you maybe have a more specific question you're trying to figure out?
I'm writing code for generating a DXF for Acad2000. It is simple to write a
"only entities" dxf for older version, but in the 2000 version there are
many parts and many relation which are not clear for me.
In the help file i have found a list of all the components of this file and
a list of codes for each component, but not a description of this and of the
relation between this. From the help topics, i don't understand these
things.
