((0 . "HATCH") (100 . "AcDbEntity") (8 . "0") (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 .
"_SOLID") (70 . 1) (71 . 0) (91 . 1) (92 . 7) (72 . 0) (73 . 1)) (list (cons 93 (length l))) l '((97 . 0) (75 . 1) (76 . 1) (47 . 1.0) (98 . 1) (10 0.0 0.0 0.0))
Hi all!
I'm trying to change the hatch entity to be ANSI31 with an angle of 315 and a scale of .05.
I can't seem to find the correct dxf codes to make this possible... everytime I add or subtract what I think should be there it doesn't create the block 😞
Any help appreciated!
Thanks!
Christina
@ckako301 wrote:((0 . "HATCH") (100 . "AcDbEntity") (8 . "0") (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 .
"_SOLID") (70 . 1) (71 . 0) (91 . 1) (92 . 7) (72 . 0) (73 . 1)) (list (cons 93 (length l))) l '((97 . 0) (75 . 1) (76 . 1) (47 . 1.0) (98 . 1) (10 0.0 0.0 0.0))....
Appropriate entity-data item numbers from the DXF Reference [some things vary by version, but I don't think any of these]:
2 Hatch pattern name
70 Solid fill flag (solid fill = 1; pattern fill = 0)
52 Hatch pattern angle (pattern fill only)
41 Hatch pattern scale or spacing (pattern fill only)
So you want to replace (2 . "_SOLID") with (2 . "ANSI31"), (70 . 1) with (70 . 0), and you seem to be missing entries for the angle and scale: (cons 52 (* (/ pi 4) 7)) [for angle in radians] and (41 . 0.05). I don't know about your 93 entry, or your l variable, and I haven't reviewed all the other entries.
Thanks for your reply Kent!
Here is what I modified (with the rest of the code that might be helpful :] )
(defun sb-ez-hch(pt w h s / a b c i j l);(sb-ez-hch (getpoint) 23.5 8.0 1) (setq a (nth 0 pt) b (nth 1 pt) c (nth 2 pt) i (* w 0.5 s) j (* h 0.5 s)) (setq l (mapcar '(lambda (x) (cons 10 x)) (list (list (+ a i) (+ b j) c) (list (+ a i) (- b j) c) (list (- a i) (- b j) c) (list (- a i) (+ b j) c)))) (entmake (append '((0 . "HATCH") (100 . "AcDbEntity") (8 . "0") (100 . "AcDbHatch") (10 0.0 0.0 0.0) (210 0.0 0.0 1.0) (2 . "ANSI31") (70 . 0) (71 . 0) (cons 52 (*(/ pi 4)7)) (41 . 0.05) (91 . 1) (92 . 4) (72 . 0) (73 . 1)) (list (cons 93 (length l))) l '((97 . 0) (75 . 0) (76 . 1) (47 . 1.0) (98 . 1) (10 0.0 0.0 0.0)) ) )
It still does not create the hatch though...
Thank you for your help 🙂
Christina
@ckako301 wrote:....
Here is what I modified .... It still does not create the hatch though...
One thing I notice is that you have a "quoted" list with a (cons) function inside it. A "quoted" list, starting with an apostrophe and a left parenthesis, needs to contain only information to be taken literally [I think that's what "quoted" represents], and nothing that needs to be evaluated -- no variable names, no calculations, etc. The (cons) function contains a calculation for the angle, which won't be evaluated in a quoted list. You would need to use the (list) function explicitly, and within that, "quote" the mini-lists [dotted pairs, etc.] that are to be taken literally, because if you don't, it will try to take the numbers following the left parentheses as function names.
(entmake (append
(list '(0 . "HATCH") '(100 . "AcDbEntity") '(8 . "0") '(100 . "AcDbHatch") '(10 0.0 0.0 0.0) '(210 0.0 0.0 1.0) '(2 . "ANSI31") '(70 . 0) '(71 . 0) (cons 52 (*(/ pi 4)7)) '(41 . 0.05) .... etc.
[See the AutoLISP Reference about (list) and (quote).] Try changing that, and see whether there are any remaining problems.
If you just need to change the hatch why not....
(defun c:test () (setq hpn (getvar "hpname") hps (getvar "hpscale") hpa (getvar "hpang")
) (command "_-hatchedit" pause "_P" "ANSI31" "0.5" "315") (setvar "hpname" hpn) (setvar "hpscale" hps) (setvar "hpang" hpa) (princ) )
