David,
How about view? Are you using R2000+?
(command "_.-view" "_sei");southeast isometric or (command "_.vpoint" "1,-1,1")
(command "_.-view" "_nei");northeast isometric or (command "_.vpoint" "1,1,1")
(command "_.-view" "_swi");southwest isometric or (command "_.vpoint" "-1,-1,1")
(command "_.-view" "_nwi");northwest isometric or (command "_.vpoint" "-1,1,1")
Use cond to compare the current view direction to the closest vpoint isometric
direction and use either view or viewpoint.
Doug
"David Bethel" wrote in message
news:2F915BB6AF8AC0A1FC1D1806E233523A@in.WebX.maYIadrTaRb...
> Greetings,
> Okay, I have a saved perspective view with the following values:
> Table Name - (0 . VIEW)
> Item Name - (2 . PRES)
> Flag - (70 . 0)
> View Height - (40 . 76.0021)
> View Center - (10 0.0 0.0)
> View Width - (41 . 103.757)
> View Direction - (11 -168.101 336.202 136.784)
> View Target - (12 -6.00175 7.99912 31.0)
> Lense Length - (42 . 50.0)
> Front Clip Plane - (43 . -19.8463)
> Rear Clip Plane - (44 . -19.8463)
> Twist - (50 . 0.0)
> View Mode - (71 . 1)
> How can I make a regular isometric view, using (command) to come close to
> the same values:
> CAMERA, TARGET, VIEWSIZE, VIEWCTR etc
> I can use VPOINT, ZOOM, PAN commands. No entmakeing tables objects. Number
> of REGENS doesn't really matter.
> TIA -David
