Visual LISP, AutoLISP and General Customization
CADAPLUS
250 Views, 1 Reply
DVB sample
Hi I'm trying to do a simple dialog box with VBA
(defun c:sample ()
(vl-load-com)
(vl-vbaload (findfile "test.dvb"))
;(vl-vbarun "something_here")
(princ)
How should I modify my dvb file?
Thanks for help
1 REPLY 1
in reply to: CADAPLUS
Hi cadaplus,
Without knowing what is in your DVB file it's a bit hard to guess how
you should modify it.
However, first you should modify your lisp so that after the DVB file is
fixed the lisp can use it.
(defun c:sample ()
(vl-load-com)
(vl-vbaload (findfile "test.dvb")) ; The "findfile" is superfluous
; as the vl-vbaload will find the
; file if findfile is capable of
; finding it
(princ)
A better lisp function is:
(defun c:sample ()
(vl-load-com)
(If (findfile "test.dvb")
(vl-vbarun "test.dvb!something_here")
(Alert "Test.dvb not found")
(princ)
Assuming your DVB file has a form with the name "Form1" then the
"something_here" has to look like:
Sub something_here ()
Form1.Show
End Sub
Laurie Comerford
cadaplus wrote:
> Hi I'm trying to do a simple dialog box with VBA (defun c:sample ()
> (vl-load-com) (vl-vbaload (findfile "test.dvb")) ;(vl-vbarun
> "something_here") (princ) ) How should I modify my dvb file? Thanks for
> help
”Boost
