draworder within blocks
26 REPLIES 26
Message 1 of 27
525 Views, 26 Replies
The express tools cdorder does this - but i'd like to automate it more
I also like the 'handles' solution becuase it is better between xrefs - and
draworder/sortents corruption seems to be a bit of a problem on 2004
stations
as a side note:
draworderctl is 3
sortents is 127
treedepth is 3020
I tried the following:
gather all hatch layers in the drawing (including with blocks)
then step through all objects and if they are not on one of the hatch layers
do an (entdel en) (entdel en)
I tried the same approach stepping through a block but the results are
mixed.
we have large elevations ($ 450 million tower) with all kinds of blocks with
multiple hatches... and running draworder during refedit can causes
thousands of erros ( in the sortents table) I even downloaded the lisp from
autodesk which 'fixes' sortents table stuff...but to no avail.
And cdorder doesn't really do a good job either.
Any ideas?
(2004 sp2 win xp sp 2)
Jamie
26 REPLIES 26
Message 21 of 27
Jamie,
Sorry about the delayed reply.
The code I posted is "dangerous" in the sense if anything goes wrong while copying
and erasing objects within block definitions, you might end up with corrupt or
incomplete blocks. For instance, there is no error checking for locked layers.
Joe Burke
"The Dark Princess" wrote in message
news:6012462@discussion.autodesk.com...
I have tested the code and it does exactly as you described, my fault for
not understanding it at first.
I only need to tweak the if statement...
Again, if you please, what does the 'dangerous bit' refer to?
Jamie
"Joe Burke" wrote in message
news:6012106@discussion.autodesk.com...
Jamie,
Again you fail to reply to the question asked. "Post an example file which
demonstrates the code I posted does not work." Whether it is dangerous or
not has
nothing to do with the validity of the code.
Joe
"Princess Jamie" wrote in message
news:6011157@discussion.autodesk.com...
perhaps you can explain the bit dangerous part.
Jamie
news:6011028@discussion.autodesk.com...
Post an example file which demonstrates the code I posted does not work.
Joe
news:6010317@discussion.autodesk.com...
Thank you for your input.
This does nothing in addressing the problem, namely revising the handles of
objects within blocks so that these objects will be visually above the other
objects, but it teaches me more about vlisp which is great.
Jamie
news:6004006@discussion.autodesk.com...
Jamie,
Something like this for the blocks. Test it on copies of working files. It
is a
bit dangerous.
Joe
[code]
;; Hatch to back in blocks example.
;; Minimal error checking.
(defun c:H2B ( / doc blocks copylst)
(setq doc (vla-get-ActiveDocument (vlax-get-acad-object)))
(setq blocks (vla-get-blocks doc))
(vlax-for x blocks
(if
(and
(zerop (vlax-get x 'IsXref))
(not (eq "*MODEL_SPACE" (strcase (vlax-get x 'Name))))
(not (eq "*PAPER_SPACE" (strcase (vlax-get x 'Name))))
(vlax-for i x
(if (not (eq "AcDbHatch" (vlax-get i 'ObjectName)))
(setq copylst (cons i copylst))
(if copylst
(progn
(vlax-invoke doc 'CopyObjects (reverse copylst) x)
(mapcar 'vla-delete copylst)
(setq copylst nil)
(vla-regen doc acActiveViewport)
(princ)
) ;end
[/code]
news:6003242@discussion.autodesk.com...
sorry Joe! sorry sorry - here, have a timbit...:-)
on the bottom please
so I need to copy the entites in the block other than hatches and entities
on hatch layers....
got it
not sure how to do that while stepping through the block's objects
Jamie
Message 22 of 27
ah, thanks. I have considered the locking of layers in other portions of
the code. I was thninking that might be the case. Thanks
Jamie
news:6015888@discussion.autodesk.com...
Jamie,
copying
or
layers.
Joe Burke
Jamie
Jamie,
not has
Joe
Jamie
Joe
Jamie
Jamie,
is a
bit dangerous.
Joe
[code]
(vlax-for x blocks
(if
(and
(vlax-for i x
(if copylst
(progn
(setq copylst nil)
(princ)
) ;end
[/code]
on hatch layers....
got it
Jamie
Message 23 of 27
Jamie,
...heeheehee. Joe- you are a funny guy.
And now back to "The Bickersons"...
David Kozina
Message 24 of 27
David,
I meant what I said. No humor or sarcasm intended.
Regards
Joe
"David Kozina" <"David Kozina"> wrote in message
news:6017165@discussion.autodesk.com...
Jamie,
David Kozina
Message 25 of 27
craigswancott
The code which you published is exactly what I need to overcome a similar problem, unfortunately I keep getting an error '; error: AutoCAD.Application: Object not in database' I am using Acad2009. All my blocks are in modelspace and are hatched using solid hatch, so I have tried substituting AcDbHatch with AcDbSolid, just in case, but with the same results. Could it possibly be because not all my blocks contain hatch.
Apologies for butting in on the old thread, but I think this is the most appropriate method, anyway any help would be greatly appreciated.
Regards
Craig
Message 26 of 27
craigswancott
I need to change the draworder of hatch within blocks, to send it to the back. I have created the blocks the correct way, but when they are inserted into a new drawing the order gets mixed up.
I have looked at the posting and the code written by Joe, but I can not get this to work using AutoCAD 2009. It would not matter if all hatch within the drawing was sent to the back, as long as this could include the hatch within blocks. Maybe I am missing something simple in running the code?
Please could someone kindly help me with this, as I do not know where to start.
Many Thanks.
Craig.
Message 27 of 27
it's easier for us to rely not on draworder which
establishes a dictionary that may not be honored in xrefs -blocks in your case-
RATHER make use of the order in which entities are created and make sure
SORTENTS = 48
to send your hatch to the back:
._COPY _ALL _Remove <select the hatch> 0,0
0,0
._ERASE _Previous
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
I
drawing the order gets mixed up. I have looked at the posting and the code
simple in running the code? Please could someone kindly help me with this, as
I do not know where to start. Many Thanks. Craig.
”Boost
