I am looking for an AutoCAD command that prompts the user to draw civil lines. When you type 'map', it will ask you: north or south, then what degree, minutes, seconds, then west or east, then last the distance, then the autocad will draw a line on the exact direction you gave the info, then repeat, until the property line closes. It sounds like a lisp routine, but I haven't been able to find it at my new employer. I remember using it in AutoCAD 2000. Does anyone know anything about it?
Thanks!
