Draw circle, extrim inside circle, erase circle
3 REPLIES 3
Daniel_Cadcon
2033 Views, 3 Replies
So i am completely in over my head with this LISP stuff. I wanted to try and write a simple routine to try and automate a few processes i do manually within a drawing. Basically i wanted to draw 2 seperate circles with a set radius at a selected point(circle 1 with a radius of 0.75, circle 2 with a radius of 1.1), trim all lines inside circle 2, and then delete circle 2.
After lots of time on different websites/forums and trying to copy parts of this code and parts of that code, i got some of my routine to work. I can succesfully draw the 2 circles at the set radius, but when i got to the EXTRIM command thats when it all started to go flying over my head. I couldn't even get my routine to erase the second cirlce. Any help would be greatly appreciated, even being pointed in the right direction. Here is my attampt at the routine, keeping in mind that i am very much only just starting to understand the basics of LISP.
(defun c:station ()
  (setq pt1(getpoint))
      (command "circle" pt1 0.75)
      (setq circle_2 (command "circle" pt1 1.1))
Daniel
3 REPLIES 3
hmsilva
in reply to: Daniel_Cadcon
Hello Daniel,
something like this perhaps...
(defun c:station ( / circle_2 pt1)
(if (setq pt1 (getpoint "\nEnter the center point: ")) (progn (command "circle" pt1 0.75) (command "circle" pt1 1.1) (setq circle_2 (entlast)) (load "extrim") (etrim circle_2 pt1) (entdel circle_2) ) ) (princ) )
Henrique
Daniel_Cadcon
in reply to: hmsilva
Thank you Henrique!
It seemed to work until it it got to one part of the extrim code and then would return a error, so i replaced that section of the code with marko_ribar's code for extrim from CADtutor that i fond online and it works! Code looks like this.
(defun c:station (/ circle_2 pt1)
  (if (setq pt1 (getpoint "\nSelect Station Point: "))
      (load "extrim")
(acet-error-init (list
                   (list   "cmdecho" 0
                         "highlight" 0
                         "regenmode" 1
                            "osmode" 0
                           "ucsicon" 0
                        "offsetdist" 0
                            "attreq" 0
                          "plinewid" 0
                         "plinetype" 1
                          "gridmode" 0
                           "celtype" "CONTINUOUS"
                         "ucsfollow" 0
                          "limcheck" 0
                   T     ;flag. True means use undo for error clean up.
                   '(if redraw_it (redraw na 4))
                  );list
);acet-error-init
(acet-error-restore)
       (entdel circle_2)))
  (princ)
Thank you again for your help!
hmsilva
You're welcome, Daniel
Glad you got it sorted.
Henrique
”Boost
