Does anyone know if we'll be seeing a DOSLIB version 20 that is compatible with AutoCAD 2015?
Solved by paullimapa. Go to Solution.
You can try the beta version on their website:
Do you use the block librarian lisp routine?
We have been using this for 18 years, its a brilliant aide.
my problem is it doesn't work properly with acad 2011 on, ie adding groups and slide refresh.
Does anybody have an updated version or want to try to fix the lisp routine for acad 2015?
