Here is roughy I wrote years ago. Always meant to "pretty" it up, but it
works well.
You select a line of the type you wish to join. It selects all entities on
that layer and uses the PEDIT command to join them together if it can.
Good for when I get files from other programmes that has all individual
lines.
Jon
"m_johnson" wrote in message
news:f089c53.-1@WebX.maYIadrTaRb...
> We are running LT2000 with the LT Toolkit. We have a lisp routine that
mends 2 lines or arc segments into one single object. Basically, the
opposite of 'Break'.
> Does anyone have a similar routine that would mend a series of multiple
lines in one go. I am told there was a command that did this in AutoCAD AEC.
This would speed things up a lot. If anyone needs the original 'mend'
routine, I can post this. Thanks in advance for any response.
