Visual LISP, AutoLISP and General Customization
Do this if the drawing name is not equal to this...
7 REPLIES 7
Message 1 of 8
scotts
599 Views, 7 Replies
So I want to write a quick little log when I open drawings and I want it to run automatically but only if the drawing name is not equal to "drawing..." since Civil 3D always starts with drawing1 and any new drawings are named drawing2, drawing3, etc.  It seems to always evaluate yes even in drawings named "Drawing1".  What am I doing wrong?
(vl-load-com)
(defun toDate (var format)
  (menucmd (strcat "m=$(edtime,$(getvar," var ")," format ")"))
);defun
(defun C:CSW-Make_User_Log_On_Open ()
  (if (/= (getvar "dwgname") "Drawing*")
    (progn
       (setq log (open (strcat "U:/IND-CAD-DIR/Z-User_Log/" (getvar "loginname") "-log.csv") "a"))
       (write-line (strcat "DRAWING OPENED:," (getvar "dwgprefix") (getvar 'DWGNAME) "," "DATE:," (toDate "DATE" "MO-DD-YYYY HH") ":" (toDate "DATE" "MM") "," "EDIT TIME:," (rtos (acet-edittime-total) 2 8) "\n") log)
       (close log)
    );progn
  );if
  (princ)
);defun
7 REPLIES 7
Message 2 of 8
pbejse
in reply to: scotts
look into (getvar 'DWGTITLED)
 As for your code
(not (wcmatch  (getvar "dwgname") "Drawing*"))
Message 3 of 8
scotts
in reply to: pbejse
Thanks I can get it to evaluate correctly, but it still doesn't run the code if it evaluates to true.  I'm guessing I'm not using the progn function properly.
Message 4 of 8
pbejse
in reply to: scotts
You can do it. what will be the resullt for (rtos (acet-edittime-total) 2 8)? that doesnt to work for me here
Edit: (acet-edittime-enable 1) need this to work on my cad
it appears to be working here scotts
Message 5 of 8
scotts
in reply to: pbejse
I think it will nil out if your drawing doesn't have edittime set to on and the drawing hasn't been saved (with edittime on).
-Scott
Message 6 of 8
pbejse
in reply to: scotts
-Scott
Yup. i would suggest you use
(if (= (getvar 'DWGTITLED) 1) ;1 means the drawing have been saved
(do this)
Message 7 of 8
scotts
in reply to: pbejse
Got it to work.  I was using "1" instead of just 1 for the evaluation.  Got to watch my syntax.  Thanks for your help, now to create a reactor that will run it when i close a drawing!Smiley LOL
Message 8 of 8
pbejse
in reply to: scotts
Good for you, Glad i could help
Cheers
”Boost
