Dear All,
I want to select no of lines & arcs
And then want to dicide them equally if I give the number say 100
so that 100 equal segments will be done for these segments
Kindly give me solution for above.
- Sanjay
Currently I am doing as below
(defun segments()
(setq secs
;(if (numberp _sdsec_)
; _sdsec_ ; then
(if (zerop (rem entlen _sdmax_)); else
(fix (/ entlen _sdmax_))
(1+ (fix (/ entlen _sdmax_)))
); end if and else
;); end if
seclen (/ entlen secs)
); end setq
);segments
;;;;;;;drawarc
(defun DrawArc
(data numSeg / arcobj stpoint edpoint arad entlen seglen)
(setq arcobj (vlax-ename->vla-object data))
(setq stpoint (vlax-curve-getstartpoint arcobj)
edpoint (vlax-curve-getendpoint arcobj)
arad (vlax-get-property arcobj 'Radius)
entlen (vlax-get-property arcobj 'arcLength)
seglen (/ entlen numSeg)
(segments)
(if (= _sdmax_ seclen)
(setq seclen (- seclen 0.00001)))
(subdiv ent (1- secs))
);DrawArc
(setq ssall(ssget))
(defun main1()
(if ssall
(progn
(setq numentall (sslength ssall)
counta 0)
(while (> numentall counta)
(setq entall (ssname ssall counta)
entdata (entget entall))
(setq ss1(ssadd))
(ssadd entall ss1)
(if ss1
(progn
(setq numents (sslength ss1)
count 0)
(setq ent (ssname ss1 count)
entdata (entget ent))
(cond
((= (cdr (assoc 0 entdata)) "ARC")
(if (= a1 "BP")
(setq _sdmax_ seclen1)
(DrawArc ent 1)
(cond
((= (cdr (assoc 0 entdata)) "LINE")
(if (= a1 "BP")
(setq entlen (vlax-curve-getDistAtParam ent (vlax-curve-getEndParam ent)))
(segments)
(setq segcount (+ segcount secs))
(setq counta (1+ counta))
);while end
);end main1
@Anonymous wrote:
.... I want to select no of lines & arcs
Try this out. It works on Lines, Arcs, Circles, Polylines, Ellipses, and Splines, open or closed. And it has some interesting options -- see comments at the top of the file.
Kent thanks for your reply,
I used your programme
but it has one problem
when you pass no of segments say 100 to second polyline it gives me correct segments of 100 polylines
but when I explode it turns into line and arcs and this time number gets adds up , it goes to 102 or 103
I want eaxct no of arcs & lines for both the polylines.
I want a simple programme where it will capture as below
1) I have polyline contaiing arcs lines I first explode it
2) programme should pick these arcs & lines
3) it will ask for segment length say (0.3)
3) then it will create no of segments say 100
4) I have another polyline contaiing arcs lines I will explode it
5) then this no 100 I will pass to another arcs & lines
so it will pick these arcs & lines
6) programme should create exact 100 segments
Attached programme for your ref.
