display slide image in a *.vlx file
0 REPLIES 0
Message 1 of 1
202 Views, 0 Replies
I have created quite a complex program using many external functions and references. Among them is a slide library (SLB) which is called up and displayed in a dialog box (controlled by a DCL file). When I create an application usig "new application wizard" , I can select LSP files and all and DCL file, but when I select SLB extension files in the support files, they are ignored in the application. Consequently, the program "fires-up" as it should but the images are not displayed in the dialog box. Is there any fix for it? Can anything be done?
0 REPLIES 0
”Boost
