Guys, Can you please help me on this, im looking for a lsp that can display the length (inserted text) measured from vertex 1 to any point that i click on a 3d polyline? Any help is highly appriciated. Thanks Guys!
Solved by CADaSchtroumpf. Go to Solution.
Solved by Kent1Cooper. Go to Solution.
Solved by pbejse. Go to Solution.
Hi CADaStroumph, sorry for the late reply. I've been away and not able to test this. I will as soon as possible.
on the other hand, as per your original routine which iam using right now (thanks to you again), is it possible to update the values inside the inserted block, once a portion of the 3d polyline change? so i dont need to re-insert those block that is not affected. something like Attsync?
