Turns out I can change the sytle with vlax too (wicked simple...can't believe I shied way from vla-vlax for so long) though it does not preserve the overrides as the entmod method does. I assume I would have to read out all the vlax properties I want to keep, then read them back in to the changed dimension...is this right?
If so, is there an easy way to read out everything about a dimension object (similar to your dump routine), change a few things in that readout (like 'StyleName and 'ScaleFactor) and then 'reverse dump' it back into the dimension?
I have to say, this has been rather eye opening, thank you.
dRew
Thanks again,
Drew
