jrossco wrote:
> Hello, I wrote a program to update our old drawings before moving them
> into Vault. It audits the drawing, grabs some text or mtext from the
> title and gets some block attributes. It takes this data and adds it
> to some properties. Then, it wblocks the whole drawing to a new
> location to be checked into Vault. Today I noticed some whacked out
> dimensions in the drawing. The appear off in space (model) and seem to
> dimension nothing. When I select one of these dimension, another
> dimension with the same appearence that is in the correct location
> highlights also. If I delete it, the other dimension is deleted too. I
> was flipping out because I've put a couple thousand files in Vault.
> (not all have this problem) Then I discoved if the dimensions are
> "Updated", they straighten out. Anyone seen this before? Also, how can
> I proram (lisp) the updating of all dimensions in a drawing? Thanks,
> have a good week end. Jrossco
If these are annotative dimensions, it sounds as if you are seeing
instances of them at more than one scale. Like, your plot is at
1/8"=1'-0", but the dimensions also display when the annotation scale is
set to 1/4"=1'-0." When you select the 1/4" version, the 1/8" version
highlights as well, because they are just two representations of the
same dimension.
Why they would be off in space, I do not know.
