It sounds to me like you're talking about setting DIMPOST to "FD" and then using DIM UPDATE to change the suffix in existing dimensions. If so, then yes, that will also change the dimension's overall scale to whatever is current, as well as everything else about it (style, dimension-line suppression, etc.), because that's what DIM UPDATE does.
But what I suggested *only replaces the suffix content* [or adds it, if the selected dimension doesn't have one], *without* updating anything else about the dimension, so it doesn't change its scale. [I tried it on dimensions whose overall scale was different from the current one, and it didn't affect that.] It doesn't even require you to change the current DIMPOST setting, or even to have one at all.
You *would* need to do it separately to *both* of those differently-scaled dimensions in each location, as written. But a slightly longer routine could be made that would let you just pick as many dimensions as you want, of both scales, and have it change the suffix on [or add it to] all of them at once, without altering anything else about them.
Kent Cooper
HT wrote...
If I update the dimension at a scale of 12 from "VIF" to "FD" i am golden, but if I also change the dimension string at a scale of 2 then it changes that dimension string to a scale of 12.....
Kent Cooper, AIA
