Hallex
Message 11 of 17 (175 Views)
Re: Dimension export routine modification
12-10-2012 09:58 PM in reply to: JoeMerry
Hi Joe
Try revisited code, this is just slightly tested,
so let me knof how it will do the work
Active Member
JoeMerry
Message 12 of 17 (166 Views)
12-11-2012 06:30 AM in reply to: Hallex
Works fantastic! The only minor issue i see is that is places the numbers in decending order, largest to smallest. If that could be fixed in the routine it will be perfect, if not no biggie we can do it via excel.
Thanks a ton for all your effort!!!
Joe
Hallex
Message 13 of 17 (163 Views)
12-11-2012 07:12 AM in reply to: JoeMerry
Hi Joe,
Again show me file or picture coz I could not understand this good enough
Do you want to sort all the data by row or by column?
Active Member
JoeMerry
Message 14 of 17 (158 Views)
12-11-2012 07:34 AM in reply to: Hallex
Hallex,
The way you have it going horizontal across the screen is perfect (by rows). The example excel I sent you shows the largest to lowest numbers left to right. We discovered this morning that we need to list the smallest number first ascending to the largest. Smallest far left, largest far right. Opposite of what I showed in my example. Just need to reverse the order of placement in excel.
I do apologize for any confusion I am causing.
Hallex
Message 15 of 17 (153 Views)
12-11-2012 08:30 AM in reply to: JoeMerry
Well I added sort by row in there
see how it works
Active Member
JoeMerry
Message 16 of 17 (146 Views)
12-11-2012 10:41 AM in reply to: Hallex
Wonderful!!! Looks and work great Fixo....thanks a ton for your patience and energy.
Hallex
Message 17 of 17 (142 Views)
12-11-2012 11:18 AM in reply to: JoeMerry
Very glad if that helps to do your job
Happy coding :smileyhappy:
~'J'~
