Visual LISP, AutoLISP and General Customization
diesel and xref
2 REPLIES 2
156 Views, 2 Replies
diesel and xref
is there anyway to have a disel expression, the filename in an xref and not have it changed when xref into another drawing, everytime i try it, the expression in the xref changes to the drawing its referenced into. thanks
2 REPLIES 2
so sounds like you are using Rtext or fields.
I would say no, you have to "hardcode" the text to the filename, do not make it reactive with diesel.
goduke21 <>
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
Here is what I have been using for ten years:
Automatically updates with my redefined save command. (updates text on that
layer)
Directory: F:\Jobs\2003\031226\acad\ File: A2-01b.dwg Date: March 05, 2005
4:14 p.m. Scale: 1=96 By: CAD_5 Xref's: ("2436TB" "BL-01" "SEAL"
"UTB21032" "UTC21190")
For a moment, nothing happened...
Gary Fowler
Then, after a second or so, nothing continued to happen.
wrote in message news:4920012@discussion.autodesk.com...
”Boost
