Visual LISP, AutoLISP and General Customization
Determine if a specific layer is VPthawed or VPfrozen?
2 REPLIES 2
scot-65
477 Views, 2 Replies
In paper space there are more than one floating view ports.
Each one has a unique set of VPLAYER freeze/thaw properties.
When a user double-clicks a view port to become active,
how can I determine if a specific layer in that view port is
either VPthawed or VPfrozen?
Actually, I will apply this to command VPMAX, but for now it makes no difference.
(This is a reactor exercise)
Thanks in advance.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
2 REPLIES 2
_gile
in reply to: scot-65
You can find the frozen layers in the extended data of the viewport (registered application = "ACAD"), the 1003 group code stands for frozen layer names.
Gilles Chanteau
GileCAD
GitHub
scot-65
Gile provided somewhat a hint.
For those curious to learn this answer, here is the code:
;get entity name of desired layer and check if it exists [layer 0 is the example]
(if (setq a (tblobjname "LAYER" "0"))
 (progn
  ;one method to get viewport entity data and create a list of vpfrozen layer entities [DFX 331]
  (setq b nil)
  (foreach x (entget (ssname (ssget "X" (list
    (cons 0 "VIEWPORT")(cons 410 (getvar "CTAB"))(cons 69 (getvar "CVPORT")))) 0))
   (if (= (car x) 331) (setq b (cons (cdr x) b)) );if
  );foreach
  ;test if desired layer is in entity list
  (cond
   ( (not b) (alert "All VPLayers are thawed. ") )
   ( (member a b) (alert "VPLayer \"0\" is frozen.  ") )
   (T (alert "VPLayer \"0\" is thawed.  ") )
  );cond
  (setq a nil b nil)
 );progn
 (princ "\nLayer \"0\" does not exist. ")
);if
(princ)
Scot-65
”Boost
