If I have an open polyline with more than 2 vertices, and I select (using entsel) the pline near one end, how could I determine the point (x,y)of the end I picked nearest to and not the other end?
I can only generate a points list of the pline and go no further.
thanks for any help ...I'm stumped
@Anonymous wrote:If I have an open polyline with more than 2 vertices, and I select (using entsel) the pline near one end, how could I determine the point (x,y)of the end I picked nearest to and not the other end?
I assume you mean the nearest extreme end of the Polyline, not necessarily the nearest segment endpoint [which you could get with (osnap)]. For that, the Polyline's (vlax-curve-...) values are probably the best source. One way to do it [untested]:
(setq
plsel (entsel "\nSelect Polyline: ")
plent (car plsel)
plCloserEnd (if
(vlax-curve-getDistAtPoint
plent
(osnap (cadr plsel) "_nea")
(vlax-curve-getDistAtParam
plent
(vlax-curve-getEndParam plent)
2
); end /
); end <
(vlax-curve-getStartPoint plent)
(vlax-curve-getEndPoint plent)
); end if & plCloserEnd
); end setq
A little curiosity I've discovered: If you use
(vlax-curve-getDistAtPoint plent (vlax-curve-getEndPoint plent))
instead of the Param versions to get an object's overall length, it will return 0 for closed things, whereas the Param version returns the length correctly whether the object is open or closed. In your particular case of open Polylines, either would work [after all, for a closed Polyline, the same point would be returned no matter where you pick on it, anyway].
Hey thanks Kent that work very nicely.
I must admit I have never used those valx-curve-xxx functions before. So I have learnt something interesting from you! Beats me why that family of functions are called vlax-CURVE when 95% of the time the user is dealing with striaght plines, lines etc.
@Anonymous wrote:Hey thanks Kent that work very nicely. ....
.... Beats me why that family of functions are called vlax-CURVE when 95% of the time the user is dealing with striaght plines, lines etc.
You're welcome, and yes, that "curve" thing is a surprise to a lot of people -- I used to wonder about it, too, but I've gotten used to it.
I just noticed a bit of wacky formatting in the code I posted:
plCloserEnd (if
ought to be
plCloserEnd
(if
[it wouldn't affect the working of it, just the readability].
