2709 Views, 6 Replies
Deter
I got this in my email. It is a great routine. I had one like it. My question is this. I have an "UNLOCKIT" routine that will undeter or unlock it. Should I post it? Gary New Free Functions/Tools ===================================================================== Drawing Modification Deterrent This free tool creates an anonymous minsert of a selection set of geometry. This is a strong deterrent to prevent changes (by others) to the drawing because it can't be exploded or refedited. Be careful to use only on a *copy* of your drawing you intend to to send to others! DETER.VLX in the Free Stuff section of http://www.dotsoft.com. - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - -
6 REPLIES 6
Minsert and annonymous block protection is very simple to break... -- http://www.draftteam.com "Gary Fowler" wrote in message news:42120470_2@newsprd01... > I got this in my email. It is a great routine. I had one > like it. My question is this. I have an "UNLOCKIT" > routine that will undeter or unlock it. Should I > post it? > > Gary > > > New Free Functions/Tools > ===================================================================== > > Drawing Modification Deterrent > > This free tool creates an anonymous minsert of a selection set of > geometry. This is a strong deterrent to prevent changes (by > others) to the drawing because it can't be exploded or refedited. > > Be careful to use only on a *copy* of your drawing you intend to > to send to others! > > DETER.VLX in the Free Stuff section of http://www.dotsoft.com. > > - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - > >
Which is exactly why it is just a deterrent. If someone wants to, they can still access your drawing, but it takes some knowledge and a little effort. It's not that it can't be hacked, it's just a pain in the @$$ to do it. I have something similar that changes everything to layer 0, (maintains color and linetype), and also makes a minserted anonymous block. Casey "Luis Esquivel" wrote in message news:42122b7b$1_3@newsprd01... > Minsert and annonymous block protection is very simple to break... > > -- > > http://www.draftteam.com > > > "Gary Fowler" wrote in message > news:42120470_2@newsprd01... > > I got this in my email. It is a great routine. I had one > > like it. My question is this. I have an "UNLOCKIT" > > routine that will undeter or unlock it. Should I > > post it? > > > > Gary > > > > > > New Free Functions/Tools > > ===================================================================== > > > > Drawing Modification Deterrent > > > > This free tool creates an anonymous minsert of a selection set of > > geometry. This is a strong deterrent to prevent changes (by > > others) to the drawing because it can't be exploded or refedited. > > > > Be careful to use only on a *copy* of your drawing you intend to > > to send to others! > > > > DETER.VLX in the Free Stuff section of http://www.dotsoft.com. > > > > - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - > > > > > >
Yep... In basically all the cases.... just DXFOUT, edit the dxf file, find the header: AcDbMInsertBlock and change it to: AcDbBlockReference double-click on the dxf file or use DXFIN, explode the block.... and that's all. -- http://www.draftteam.com Casey Roberts" > Which is exactly why it is just a deterrent. If someone wants to, they can > still access your drawing, but it takes some knowledge and a little effort. > It's not that it can't be hacked, it's just a pain in the @$$ to do it. > > > I have something similar that changes everything to layer 0, (maintains > color and linetype), and also makes a minserted anonymous block.
> In basically all the cases.... just DXFOUT, edit the dxf file, find the > header: AcDbMInsertBlock and change it to: AcDbBlockReference > double-click on the dxf file or use DXFIN, explode the block.... and that's > all. > > -- > yes may be, but you are "Luis Esquivel" and 99,..% AutoCAD users don't know that ;o) Bruno Toniutti
Grazie Bruno, io non sono quel genere di persona astuta. Abbia un giorno piacevole. -- http://www.draftteam.com > > yes may be, but you are "Luis Esquivel" and 99,..% AutoCAD users don't know > that ;o) > > Bruno Toniutti > >
> I have an "UNLOCKIT" > routine that will undeter or unlock it. Should I > post it? Yes, I will try. But do you know that with AutoCAD Mechanical (2005) you can refedit an anonymous minsert? -- Marc'Antonio Alessi http://xoomer.virgilio.it/alessi (strcat "NOT a " (substr (ver) 8 4) " guru.") --
”Boost
