good stuff, both of you.
I have tried a lot of angles, but these are a bit different. Variety is nice.
Jeff Mishler
|>James,
|>I don't know if this is your solution, but this removes the objects that
|>forces the proxy notice.
|>(setq *doc* (vla-get-activedocument (vlax-get-acad-object)))
|>(setq dicts (vla-get-dictionaries *doc*))
|>(vlax-for dict dicts
|> (if (and (vlax-property-available-p dict 'name)
|> (wcmatch (strcase (vla-get-name dict)) "AEC*")
|> (vla-delete dict)
|>I tried removing the 4 dictionaries individually, but only the removal of
|>all of them stopped the proxy notice from appearring.
|>When opening in Land2006 only 1 of them is reinstated: AecCvDwgPointIndex
|>Hope this gets you going in the right direction....
|>Jeff
|>"James Maeding" wrote in message
|>news:5026239@discussion.autodesk.com...
|>Many of my drawings crash when plotting in LDT 2006 using the latest OCE
|>.ldf driver.
|>I believe its due to an AECCivilCogo non-graphical object for good reasons
|>The reasons are long to explain, I will if you want though.
|>I attached a drawing that crashes, it is practically blank.
|>If you open it in MAP, you will see the proxy warning box.
|>I also attached a jpg of the proxy box.
|>Can anyone tell me how to delete that non-graphical proxy object?
|>An interesting thing is that if you open the
|> drawing in a Map session, and save, the problem stops - Until you try to
|>plot in LDT. If you can help me on this, I will pay. So far, Autodesk and
|>OCE have not provided me people that could
|>do anything useful. If I could solve these crashes, it would be worth lot
James Maeding
Civil Engineer and Programmer
jmaeding - athunsaker - com
