Distinguished Contributor
5 Kudos
Post 1 of 2
Delete toobar from partial cui menu
212 Views, 1 Replies
02-15-2013 01:11 PM
I have what I think is a simple question, but I am having difficulty with it. I have a company .cuix menu that is loaded as a partial menu to the main acad.cuix file. I want to delete all the toolbars and pull down menus associated with it and leave the other stuff in place. This is in Autocad 2011 but should also translate to 2013. So far, I have tried opening the CUI menu, going to the company.cuix partial menu and deleting the toolbars. Then I hit save, then Apply. Toolbars disappear and pulldown menus go away. But when I reload AutoCAD they come back. What am I missing here?
9 Kudos
Post 2 of 2
Re: Delete toobar from partial cui menu
02-15-2013 04:47 PM in reply to: Jroper
Hi Jroper,
do not delete it just unload it.
type cui in command prompt end press enter then unload company.cuix.
see the attached screen shot of my autocad.
you can use cuix files for AutoCAD 2010-2013
and cui files for AutoCAD 2006-2009
cuix is just zipped version of cui, you can extract it via 7-zip
good luck
