Visual LISP, AutoLISP and General Customization
Delete folder command
4 REPLIES 4
2268 Views, 4 Replies
Hi everybody
I need to delete a folder (not empty) in my LISP routine and I’m not being able to do so. I created the folder using (vl-mkdir “foldername”) but I don’t find the equivalent command to remove it. Any help?
Nuno
4 REPLIES 4
This delete the folder and its content:
(setq FSO (vlax-create-object "Scripting.FileSystemObject"))
(vlax-invoke FSO "DeleteFolder" "D:\\folder1\\folder2\\Prog\\AutoLISP\\deletme" :vlax-true)
at the end release the FSO:
(vlax-release-object FSO)
Hope this helps.
Justo Aguiar.
Hello Just Aguiar,
It works perfectly. I just change from absolute path to local path (vlax-invoke FSO "DeleteFolder" ".\\foldername" :vlax-true). Problem solved!
Nuno
Any way to use a while card?
I want to delete all the Background Plot folders.
For me they are created in C:\Temp\BGPlot_2552 but the number varies.
Please let me know.
rkmcswain
I'm presuming you mean "wild" card.
In that case, give this a try:
(setq temp (getenv "temp"))
(if (setq k3 (vl-directory-files temp "BGPlot_*" -1))
  (progn
    (setq fso (vlax-create-object "Scripting.FileSystemObject"))
    (foreach x k3
      (vlax-invoke-method fso 'DeleteFolder (strcat temp "\\" x)  :vlax-false)
      (princ (strcat "\nDeleted folder [" x "]"))
    (vlax-release-object fso)
  (princ)
”Boost
