Visual LISP, AutoLISP and General Customization
Delete a Named View
3 REPLIES 3
scot-65
846 Views, 3 Replies
Delete a Named View
How do I delete a named view without closing, then reopening a custom DCL dialog box?
This is the command equivalent: (command "-VIEW" "Delete" "View01").
I can supply the view name and will send to a subroutine as shown below.
Remove one at a time:
(EVC_Remove "View01")
and
Remove all of them:
(EVC_Remove "*")
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
3 REPLIES 3
Kent1Cooper
in reply to: scot-65
Something as simple as this [minimally tested]:
(defun EVC_Remove (viewname)
  (command "_.view" "_delete" viewname)
  (princ)
Add something like this [untested] if you like:
  (prompt
    (strcat
      "\n"
      (if (= viewname "*") "All named Views" (strcat "View " viewname))
      " deleted."
    ); strcat
  ); prompt
Kent Cooper, AIA
Lee_Mac
@KenT: As far as I'm aware, you cannot evaluate an AutoCAD command whilst a modal dialog is active, as the user has indicated:
The following is untested, but may be suitable:
(defun evc_remove ( view / lst )
    (vlax-for v (vla-get-views (vla-get-activedocument (vlax-get-acad-object)))
        (if (wcmatch (strcase (vla-get-name v)) view)
            (setq lst (cons v lst))
    (and lst
        (not
            (apply 'or
                (mapcar
                   '(lambda ( x )
                        (vl-catch-all-error-p
                            (vl-catch-all-apply 'vla-delete (list x))
                    lst
Call the function with a case-insensitive view name, or wildcard pattern, e.g.:
(evc_remove "myview")
(evc_remove "*")
The function will then return T if all matching views are successfully deleted, else nil if one or more views could not be deleted for whatever reason, or if no matching views are found.
Lee
scot-65
in reply to: Lee_Mac
Thanks, I'll give it a try.
I knew it had something to do with "catch-all" and "vla-delete", but I am not that proficient with VL.
I populate the list_box using (tblnext "VIEW"... so there is no problem with text case. After this action you provided I will call again the tblnext to repopulate... In no way the user will ever type the view name.
And Yes, no commands allowed while the DCL is open.
Scot-65
”Boost
