Hi guys,
I am working on a litle lisp routine to draw splines, but can't get it working. The basic idea is that i first select a set of points that i can feed to my spline command.
(defun c:test2 () (setq pt (getpoint "\n define point:")) (setq ptlist nil) (while (not (equal pt nil)) (setq ptlist (cons pt ptlist)) (setq pt (getpoint "\n define point:")) ) )
Now i need to draw a spline based on these points.
My plan whas to simply use the acad command itself
But this option didn't work.
(command "spline" ptlist "" )
Then i tried using the vla-addspline command.
But i can't even get this one working 😛
Can enybody help me whit this problem?
Regards
Thomas
Solved by pbejse. Go to Solution.
Solved by stevor. Go to Solution.
Hi Thomas,
Here is an example that uses vla-addSpline:
(defun c:spltest (/ acadapp acaddoc
*ModelSpace* ptStartTan ptEndTan
ptFit1 ptFit2 ptFit3
ptFit4 FitPoints ptlstlen
FitPointsDataA FitPointsData
StartTanA StartTan EndTanA
EndTan mySplineObj
(vl-load-com)
(setq acadapp (vlax-get-Acad-Object)
acaddoc (vla-get-ActiveDocument acadapp)
*ModelSpace* (vla-get-ModelSpace acaddoc)
;;set start & end tangent values
(setq ptStartTan (list 0.0 0.0 0.0)
ptEndTan (list 0.0 0.0 0.0)
;;set fit point values
(setq ptFit1 (list 1.5 3.5 0.0)
ptFit2 (list 4.5 5.5 0.0)
ptFit3 (list 6.5 1.5 0.0)
ptFit4 (list 11.0 3.0 0.0)
;;create list of the fit point values
(setq FitPoints
(apply 'append (list ptFit1 ptFit2 ptFit3 ptFit4))
;;create a safearray to hold the fit points
(setq ptlstlen (length FitPoints))
(setq FitPointsDataA
(vlax-make-safearray
vlax-vbDouble
(cons 0 (1- ptlstlen))
;;populate the safearray
(vlax-safearray-fill FitPointsDataA FitPoints)
;;assign the safearray to a variant
(setq FitPointsData
(vlax-make-variant
FitPointsDataA
(logior
vlax-vbarray
vlax-vbDouble
;;create a safearray to hold the start tangent points
(setq StartTanA
vlax-vbDouble
(cons 0 2)
(vlax-safearray-fill StartTanA ptStartTan)
(setq StartTan
(vlax-make-variant
StartTanA
(logior
vlax-vbarray
vlax-vbDouble
;;create a safearray to hold the end tangent points
(setq EndTanA
vlax-vbDouble
(cons 0 2)
(vlax-safearray-fill EndTanA ptEndTan)
(setq EndTan (vlax-make-variant
EndTanA
(logior
vlax-vbarray
vlax-vbDouble
;;create the spline object
(setq mySplineObj
(vla-addSpline *ModelSpace* FitPointsData StartTan EndTan)
;;change the color of the spline
(vla-Put-Color mySplineObj acBlue)
(vla-Update mySplineObj)
(princ)
;; get the length of the spline
(setq endSpline (vlax-curve-getEndParam mySplineObj))
(princ "\nLength of Spline = ")
(vlax-curve-getDistAtParam mySplineObj endSpline)
Cheers,
Wayne Brill
Autodesk Developer Network
The 'command creation should still work, albeit the end directions must be entered.
This version seems to work, and in it the end directions are selected to go with the flow.
The commented out functions are at AusCadd.com, if using default values are of interest.
(DEFUN C:desL ( / npl pp ppp ) (redraw)
(if (and ;(setq SP*p1 (get_p SP*p1 " Start pt "))
(setq SP*p1 (getpoint " Start pt "))
;(setq SP*dp1 (get_prd SP*p1 SP*dp1 " Start Dir Pt "))
(setq SP*dp1 (getpoint SP*p1
" Start Dir Pt {towards next curve pt} "))
(setq fp1 (polar SP*p1 (angle SP*p1 SP*dp1) 1e9))
(progn
(grdraw SP*p1 fp1 5) ; towards direction spline
(setq pp SP*p1)
(while (setq np (getpoint pp " Next "))
(grdraw pp np 2) ; cord
(grdraw pp (polar np (angle pp np) 1e8) 2) ; running tans
(setq npl (cons np npl) ppp pp pp np) ; prevs
;(setq SP*dp2 (get_prd pp SP*dp2 " End Dir Pt "))
(grdraw pp (polar ppp (angle ppp pp) 1e8) 5)
(setq SP*dp2 (getpoint pp
" End Dir Pt {away from last curve pt}"))
(command "spline" SP*p1 )
(foreach np (reverse npl) ; (gr_xdc np 1 1)
(command np ) )
(command "" (polar SP*p1 (angle SP*dp1 SP*p1) 1e8)
SP*dp2 )
;(redraw)
) ) (princ) ) ;
Hi Thomas
using your method, so try
(defun c:test2 ()
(setq ptlist nil)
(command "_SPLINE")
(mapcar 'command ptlist)
(command "" "" "")
(princ)
Cheers
Henrique
Similar
(defun c:test3 ( / pt pt2 ptlist)
(if (setq pt (getpoint "\n define point:")
ptlist (list pt))
(progn
(while (setq pt2 (getpoint pt "\n define point:"))
(grdraw pt pt2 1 1)
(setq ptlist (cons pt2 ptlist)
pt pt2)
(command "spline")
(foreach
p ptlist
(command p))
(command "" "" "")
(redraw)
My apologies for waiting so long whit posting;
But i was still testing my one solution.
thank you all for the posts, this is what i finaly used:
(defun drawspl (ptlist) (setvar "osmode" 0) (command "spline") (foreach pt ptlist (command pt) ) (command "" "" "" ) )
@Anonymous wrote:My apologies for waiting so long whit posting;
Godd for you,
Thats what i did on my post too Thomas
Cheers
