Visual LISP, AutoLISP and General Customization
Default prompt on enter
8 REPLIES 8
Message 1 of 9
JCprog
1702 Views, 8 Replies
Hello everyone 🙂
I'm trying to make a default prompt selection on my rotation angle but can't seem to make it work. Please help.....Thanks in advance 🙂
  (prompt "Select Entities to Rotate")
  (setq ss (ssget))
  (setq num (sslength ss))
  (setq x 0)
  (if ss
  	(if (setq ang (getreal "\nEnter Rotation Angle [45/90/180] <45>: "))
	  	(repeat num
		  	(setq ename (ssname ss x))
		    (setq elist (entget ename))
			(setq pnt (cdr(assoc 10 elist)))
			(command "Rotate" ename "" pnt ang)
 		    (setq x (1+ x))
8 REPLIES 8
Message 2 of 9
Shneuph
in reply to: JCprog
You can check out Lee Mac's website (link below).  He explains how to do this well..  Use (INITGET...)
Prompt With Default
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Message 3 of 9
JCprog
in reply to: Shneuph
Thanks for the reply Shneuph,
I already tried Lee's, somehow cant get it to work.
Message 4 of 9
Lee_Mac
in reply to: JCprog
There are of course many ways this could be achieved depending on the behaviour you are looking for from the program; since you are restricting the user to angles of 45, 90 or 180, a getkword prompt may be more appropriate, for example:
(if (setq sel (ssget "_:L"))
    (progn
        (initget "45 90 180")
        (setq ang (atoi (cond ((getkword "\nEnter Rotation Angle [45/90/180] <45>: ")) ("45"))))
Thank you for the recommendation Shneuph!
Message 5 of 9
JCprog
in reply to: Lee_Mac
Thanks for the code Lee but it gives me this error:
; error: bad argument type: fixnump: nil
Message 6 of 9
hmsilva
in reply to: JCprog
did you copy all brackets from Lee's code?
Lee's code with other formatting, copy all code, and try it
(setq ang (atoi
		  ("45")
Henrique
Message 7 of 9
Lee_Mac
in reply to: JCprog
Sorry, but I see nothing in my posted code that would cause that error - please note that the code I have posted is by no means a complete program, but just the snippet relevant to your question.
Message 8 of 9
JCprog
Thanks for the code Lee....I finally got it to work! Smiley Very Happy
Message 9 of 9
Lee_Mac
in reply to: JCprog
Excellent to hear - you're welcome JCprog Smiley Happy
”Boost
