Hi guys,
I have this piece of magic code that increment or reduce a value on text numbers.
I can not apply decimal places in texts whose value is 100.00 for example. In others such as 100.35 works fine.
Any suggestions to correct this situation?
;c:elevar ;User is prompted to select objects for modification ;User is prompted for Value to add to number ;User is prompted for Number of Decimal Places ;Retrieves a number from the string of each text object searching the string from beginning to end ;Return first instance of a number ;Ignores text objects that have no number in them ;Adds Value to Number according to decimal format ;Replaces the string and modifies entity ;Returns (through princ) the number of entities modified (defun c:elevar () (setq ss (ssget '((0 . "TEXT")))) (setq strval (getreal "\nQual o valor a acrescentar? (para diminuir colocar o sinal -). ")) (setq cnt* 0) (if (= nil prec) (setq prec 3)) (if (= nil strval) (progn (princ "\nUser Cancelled")(exit)) (progn (setq prec* (getreal (strcat "\nQuantas casas decimais [" (itoa prec) "]?"))) (if (= prec* nil) (setq prec* (fix prec)) (progn (setq prec* (fix prec*)) (setq prec prec*)) )) ) (setq sslen (sslength ss)) (setq entmodnum 0) (while (/= cnt* sslen) (setq ent (ssname ss cnt*)) (setq entd (entget ent)) (setq str (cdr (assoc 1 entd))) (setq cnt* (+ cnt* 1)) (setq numpos* (numpos str)) (if (/= numpos* nil) (progn (setq val (substr str (nth 0 numpos*) (nth 1 numpos*))) (setq fmtval (read val)) (setq nval (+ strval fmtval)) (setq valstr (rtos nval 2 prec*)) (setq nstr (vl-string-subst valstr val str)) (setq elist (list (cons -1 ent) (cons 1 nstr))) (entmod elist) (setq entmodnum (+ entmodnum 1)) )) ) (princ (strcat "\n" (vl-princ-to-string entmodnum) " Entidades modificadas." )) (princ) ) ;end elevar ;numpos ;arguments = string ;Searches string for a number from the beginning to the end returning the first instance of the number ;Returns list ( begin_number_position length_of_number ) ;Example (numpos "Hellosam") = nil ;Example (numpos "Hellosam 1") = (10 1) ;Example (numpos "Hellosam 1: 2") = (10 1) (defun numpos (str) (setq strlist (vl-string->list str)) (setq bgnpos nil) (setq cnt 0) (setq ignore "F") (foreach ch strlist (progn (if (or (and (>= ch 48) (<= ch 57)) (= ch 46)) (progn ;ch = number OR ch = . (if (and (= nil bgnpos)(= ignore "F")) (setq bgnpos cnt))) (progn ;ch does not = number OR ch does not = . (if (and (/= nil bgnpos) (= ignore "F")) (progn (setq numlen (- cnt bgnpos)) (setq ignore "T"))))) (setq cnt (+ 1 cnt))) ) (if (= bgnpos nil) (setq poslst nil) (progn (setq bgnpos (+ 1 bgnpos)) (setq poslst (list bgnpos numlen)))) ) ;end numpos ;posnum ;arguments = string ;Searches string for a number from the end to the beginning returning the first instance of the number ;Returns list ( begin_number_position length_of_number ) ;Example (posnum "Hellosam") = nil ;Example (posnum "Hellosam 1") = (10 1) ;Example (posnum "Hellosam 1: 2") = (13 1) (defun posnum (str) (setq strlist (vl-string->list str)) (setq strlist (reverse strlist)) (setq bgnpos nil) (setq cnt 0) (setq ignore "F") (foreach ch strlist (progn (if (or (and (>= ch 48) (<= ch 57)) (= ch 46)) (progn ;ch = number OR ch = . (if (and (= nil bgnpos)(= ignore "F"))(setq bgnpos cnt))) (progn ;ch does not = number OR ch does not = . (if (and (/= nil bgnpos) (= ignore "F")) (progn (setq numlen (- cnt bgnpos)) (setq ignore "T"))))) (setq cnt (+ 1 cnt))) ) (if (= bgnpos nil) (setq poslst nil) (progn (setq bgnpos (- (length strlist) (+ (- bgnpos 1) numlen))) (setq poslst (list bgnpos numlen)))) ) ;end posnum
@Anonymous wrote:Hi guys,
set dimzin to 0, you probably had it on 8
8 Suppresses trailing zeros in decimal dimensions (for example, 12.5000 becomes 12.5)
DIMZIN also affects real-to-string conversions performed by the AutoLISP rtos and angtos functions....
HTH
