So, I am now trying to work with DCL to make my program much more user friendly and I have come into a little bit of a problem.
I have set up a dcl code with the autolisp code to give me this:
And in "Sheet Units" box where the user selects either Metric or Imperial I want the popup list below to switch between the Metric size lists of sheets or to the Imperial size lists of sheets. Right now no mattter what I pick the list is always the Imperial selection.
If anyone has any hints or ideas on how to have the list change based on which radio button is picked I would be extremely grateful!
Below is the DCL code followed the Lisp code:
//-------------------------------------------------------------------------- // PlanTemplate.LSP CREATE GRID AND PLACE COORDINATE NORTHING AND EASTINGS //========================================================================== //DESCRIPTION: This program will ask the user to outline the two corners of // the grid as well as the grid spacing and then proceed to // create the grid based on those inputs. The program also works // to create Northing and Easting labels along the grid based on // the paper size and coordinates of the grid. // // //START COMMAND........ GridCL GRIDCT // //WRITTEN BY: Chase Dowdeswell May 2014 // //////////////////////////////////////////////////////////////////////////// //--------------------------- DCL ------------------------------ //////////////////////////////////////////////////////////////////////////// Sheet_Parameters : dialog { //Dialog Name label = "Sheet Parameters" ; : row { : column { : boxed_radio_column { //Define the column label = "Offset Top Right Corner" ; //Name : radio_button { key = "rb1" ; label = "&Yes" ; value = "1" ; //switch it on } : radio_button { key = "rb2" ; label = "No" ; } } //End Boxed Radio Column : boxed_radio_column { label = "Grid Lines" ; //Name : radio_button { key = "rb3" ; label = "&Yes" ; } : radio_button { key = "rb4" ; label = "No" ; } } //End Boxed radio Column : boxed_radio_column { label = "Lines or Ticks" ; //Name : radio_button { key = "rb5" ; label = "&Lines" ; } : radio_button { key = "rb6" ; label = "Tick" ; } } //End Boxed radio Column } //End Column : column { : boxed_radio_column { label = "Sheet Units" ; : row { : radio_button { key = "rb7" ; label = "Metric" ; } : radio_button { key = "rb8" ; label = "&Imperial" ; value = "1" ; } } //End Row } //End Boxed radio column : boxed_column { //Start list label = "Sheet Type" ; : popup_list { key = "Selections" ; //Name value = "5" ; //Initial Value } //End List } //End Boxed Column : edit_box {key = "eb1"; label = "Northing Spacing"; //Northing edit_width = 12; value = "000";} : edit_box {key = "eb2"; label = "Easting Spacing"; //Easting edit_width = 12; value = "000";} : edit_box {key = "eb3"; label = "Text Orientation"; //Text Orientation edit_width = 12; value = "00";} : edit_box {key = "eb4"; label = "Scale Factor (1000s)";//Scale Factor edit_width = 12; value = "0";} } //End Column } //End Row : image { key = "im" ; //Image name height = 1.0 ; //Height width = 1.0 ; //Wdith } //End Image : paragraph { : text_part { //End Text label = "Please Select All Sheet Parameters" ; } : text_part { label = "By Chase Dowdeswell" ; } //End Text } //End Paragraph //End Row ok_cancel ; } //End Dialog
(defun c:Dialog () (setq dcl_id (load_dialog "Sheet_Parameters.dcl")) ;Load Dialog (if (not (new_dialog "Sheet_Parameters" dcl_id) ) (exit) );if (setq Dw (dimx_tile "im") ;get image tile width Hw (dimy_tile "im") ;get image tile height );setq (start_image "im") ;start the image (fill_image 0 0 Dw Hw 5) ;fill it with blue (end_image) ;end image (start_list "Selections") ;start the list_box (mapcar 'add_list SheetList) ;fill the list box (end_list) ;end list (mode_tile "rb5" 1) (mode_tile "rb6" 1) (action_tile "rb1" "(setq EvenOdd \"Yes\")") (action_tile "rb2" "(setq EvenOdd \"No\")") (action_tile "rb3" "(setq GRDYN \"Yes\") (mode_tile \"rb5\" 0) (mode_tile \"rb6\" 0)") (action_tile "rb4" "(setq GRDYN \"No\") (mode_tile \"rb5\" 1) (mode_tile \"rb6\" 1)") (action_tile "rb5" "(setq GRDTCK \"Lines\")") (action_tile "rb6" "(setq GRDTCK \"Tick\d")") (action_tile "rb7" "(setq Units \"Metric\")") (action_tile "rb8" "(setq Units \"Imperial\")") (setq Choice1 (atoi (get_tile "rb7"))) ; 0 = not chosen 1 = chosen (setq choice2 (atoi (get_tile "rb8"))) ; 0 = not chosen 1 = chosen (if (= Choice1 1) (setq Units "Metric") (setq Units "Imperial") );if (if (= Units "Imperial") (progn (setq SheetType "ANSI_A_BASIC_LAND") (setq SheetList '("ANSI_A_BASIC_LAND" "ANSI_A_BASIC_LAND_STACK" "ANSI_A_BASIC_PORT" "ANSI_A_BASIC_PORT_STACK" "ANSI_A_BASIC_LAND_VERT" "ANSI_B_BASIC_LAND" "ANSI_B_BASIC_LAND_STACK" "ANSI_B_BASIC_PORT" "ANSI_B_BASIC_PORT_STACK" "ANSI_B_BASIC_LAND_VERT" "ANSI_C_BASIC_LAND" "ANSI_C_BASIC_LAND_STACK" "ANSI_C_BASIC_PORT" "ANSI_C_BASIC_PORT_STACK" "ANSI_C_BASIC_LAND_VERT" "ANSI_D_BASIC_LAND" "ANSI_D_BASIC_LAND_STACK" "ANSI_D_BASIC_PORT" "ANSI_D_BASIC_PORT_STACK" "ANSI_D_BASIC_LAND_VERT" "ANSI_E_BASIC_LAND" "ANSI_E_BASIC_LAND_STACK" "ANSI_E_BASIC_PORT" "ANSI_E_BASIC_PORT_STACK" "ANSI_E_BASIC_LAND_VERT") );setq );progn (progn (setq SheetType "A4_BASIC_LAND") (setq SheetList '("A4_BASIC_LAND" "A4_BASIC_LAND_STACK" "A4_BASIC_PORT" "A4_BASIC_PORT_STACK" "A4_BASIC_LAND_VERT" "A3_BASIC_LAND" "A3_BASIC_LAND_STACK" "A3_BASIC_PORT" "A3_BASIC_PORT_STACK" "A3_BASIC_LAND_VERT" "A2_BASIC_LAND" "A2_BASIC_LAND_STACK" "A2_BASIC_PORT" "A2_BASIC_PORT_STACK" "A2_BASIC_LAND_VERT" "A1_BASIC_LAND" "A1_BASIC_LAND_STACK" "A1_BASIC_PORT" "A1_BASIC_PORT_STACK" "A1_BASIC_LAND_VERT" "A0_BASIC_LAND" "A0_BASIC_LAND_STACK" "A0_BASIC_PORT" "A0_BASIC_PORT_STACK" "A0_BASIC_LAND_VERT") );setq );progn );if (start_list "Selections") (mapcar 'add_list SheetList) (end_list) (action_tile "cancel" ;If cancel button pressed "(done_dialog) (setq userclick nil)" ;Close dialog );action_tile (action_tile "accept" ;If cancel button pressed (strcat ;string list together "(progn (setq SHEETTYPE (atof (get_tile \"Selections\")))" ;get list selection "(setq MajGridN (get_tile \"eb1\"))" ;Get Northing Spacing "(setq MajGridE (get_tile \"eb2\"))" ;Get Easting Spacing "(setq TextOr (get_tile \"eb3\"))" ;Get Text Orientation "(setq SheetScale (get_tile \"eb4\"))" ;get Scale " (done_dialog) (setq userclick T))" ;Close dialog );strcat );action_tile (start_dialog) ;start dialog (unload_dialog dcl_id) ;unload (if userclick ;check O.K. was selected (progn (setq SHEETTYPE (fix SHEETTYPE)) (setq SHEETTYPE (nth SHEETTYPE SheetList)) );progn );if (princ) );defun (princ)
Concentrate on these lines:
Now look at the following for hints:
;*** ACTION TILE ***
(action_tile "Rad101" "(RNLT_mode stn)")
(action_tile "Rad102" "(RNLT_mode f1n)")
Where:
(defun RNLT_mode ( a / )
(start_list "Pop302")(mapcar 'add_list a)(end_list)
);end RNLT_mode
And:
(setq stn (list "ST""SG"))
(setq f1n (list "F1""F2""F3""F4""F5""F6"))
I have attached a "template" file I use when beginning a DCL type project.
Look at it's architecture and see if you can structure your program the same way...
As a hint, gather all user input when "accept" is called, then go into the main program with this information.
I have slightly modified what you have as an example:
:radio_row {key="rb78";
:radio_button {key="rb7"; label="Metric";}
:radio_button {key="rb8"; label="&Imperial"; value = "1";}
Now, in the "GET" section, see what is rb78:
(get_tile "rb78")
You will find that it is either "rb7" or "rb8".
No need to setq in each action_tile.
Hope this helps.
Scot-65
A gift of extraordinary Common Sense does not require an Acronym Suffix to be added to my given name.
Maybe this will help...
test : dialog { label = "Sheet Parameters"; spacer; :column { : boxed_radio_row { label = "Sheet Units"; key = "radrow"; : radio_button { label = "&Metric"; key = "rb01"; } : radio_button { label = "&Imperial"; key = "rb02"; } } // end boxed_radio_row spacer; :row { : boxed_column { label = "Sheet Type"; width = 30; : popup_list { key = "sht_typ"; } } // end boxed_column } // end row } // end column ok_cancel; } // end test dialog
(defun c:test () (setq dcl_id (load_dialog "test.dcl")) (if (not (new_dialog "test" dcl_id)) (exit)) ;radio buttons (if radio_option (set_tile "radrow" radio_option) (set_tile "radrow" "rb01") ) ;list_box (setq mylist (list "AA" "BB" "CC")) (cond ((= radio_option "rb01") (setq mylist (list "AA" "BB" "CC"))) ((= radio_option "rb02") (setq mylist (list "XX" "YY" "ZZ"))) ) (start_list "sht_typ") (mapcar 'add_list mylist) (end_list) (action_tile "radrow" "(dcl_radio_01)") (setq test_dialog (start_dialog)) (unload_dialog dcl_id) ) ;column radio (defun dcl_radio_01 () (setq radio_option $value) (cond ((= radio_option "rb01") (setq mylist (list "AA" "BB" "CC"))) ((= radio_option "rb02") (setq mylist (list "XX" "YY" "ZZ"))) ) (start_list "sht_typ") (mapcar 'add_list mylist) (end_list) )
Smaher12, is there a way to attach a command to each of the list selections? i.e. Choosing "AA" runs the line command, and "BB" runs the circle command? Thanks
Scot-65
Give this a shot....
(defun c:test () (initiate) (setq p1 (getpoint "\nSpecify point: ")) (if (= radio_option "rb01") (cond ((= sht_typ "0") (command "_.line" p1 pause "")) ((= sht_typ "1") (command "_.circle" p1 pause "")) ) ) (if (= radio_option "rb02") (cond ((= sht_typ "0") (command "_.rectangle" p1 pause "")) ((= sht_typ "1") (command "_.donut" "0" "2" p1 "")) ) ) ); test (defun initiate () (setq dcl_id (load_dialog "test.dcl")) (if (not (new_dialog "test" dcl_id)) (exit) ) ;radio buttons defaults (if radio_option (set_tile "radrow" radio_option) (set_tile "radrow" "rb01") ) ;list_box defaults (setq mylist (list "AA" "BB" "CC")) (cond ((= radio_option "rb01") (setq mylist (list "AA" "BB" "CC"))) ((= radio_option "rb02") (setq mylist (list "XX" "YY" "ZZ"))) ) (start_list "sht_typ") (mapcar 'add_list mylist) (end_list) (set_tile "sht_typ" (if sht_typ sht_typ (setq sht_typ "0"))) (action_tile "radrow" "(dcl_radio_01)") (action_tile "sht_typ" "(setq sht_typ $value)") (action_tile "accept" "(done_dialog)") (action_tile "cancel" "(exit)") (start_dialog) (unload_dialog dcl_id) (princ) ); initiate ;column radio (defun dcl_radio_01 () (setq radio_option $value) (cond ((= radio_option "rb01") (setq mylist (list "AA" "BB" "CC"))) ((= radio_option "rb02") (setq mylist (list "XX" "YY" "ZZ"))) ) (start_list "sht_typ") (mapcar 'add_list mylist) (end_list) )
The lisp worked great. I did some modifications to it, and now when the dialog pops up, I have to choose a ratio button and then select an item from the drop down list. Even though it has a default value in there, if I click on, it returns nil. If I select the already selected ratio button, and then select an option from the pop-up list that is already selected, it will work. It's as though it doesn't recognize the default value for the list. Any ideas? Thanks.
Scot-65
Replace the following in the code
(if radio_option
With this
(if (= radio_option nil)
(setq radio_option "rb01")
