Visual LISP, AutoLISP and General Customization
Customize the ribbon panel in a ribbon tab
4 REPLIES 4
idragonb
2253 Views, 4 Replies
I am trying to customize Autocad 2012 ribbon tab. I can't seem to find how to mimic the small arrow that appears in several of the standard menus. For example, in the 3D Solids - Home Tab, the second panel from the left is "3D Solids Home - Mesh" It has a small arrow in the corner that opens up a preferences dialogue box.
How can I add that arrow to a custom panel with that little arrow so that I can add my command to it?
Thank you.
Michael
Flow state:
Maximum challenge with maximum skills.
4 REPLIES 4
bgingerich
in reply to: idragonb
Well, just comparing two different panels I found that in the ones that have the extra dialog box have a "key tip" and a "element_id" under the "panel dialog box launcher".  Not sure how to add/customize those though... I'll get back with you.
(if ("mysolution"=answer) then (click "Accept As Solution"))
Brandon Gingerich
bgingerich
OK.  Never knew you could do this before!  Make a command in the cui to launch the dialog box/command you want.  Then simply drag and drop the command into the "Panel Dialog Box Launcher" and you're all set.  HTH
Brandon Gingerich
bgingerich
A page from 2012 documentation for other info.  click
Brandon Gingerich
idragonb
in reply to: bgingerich
Hey bgingerich - awesome - first time that I asked a question - it sure saves headache - I'm addicted. I propose to answer 2 questions for every one that I ask. This is a good thing!!
(cond
   ((and (feedback = "good") (feedback = "quick") (feedback /= "difficult")) "give back")
   ( T ("/nThanks for the quick response!"))
Flow state:
”Boost
