Well, here's my list of a few new items:
A> An improved command line that parses commands and Lisp (c:..) functions by a
delimeter (e.g., ';') so you can enter multiple commands one one line. Each
delimeter acts as a single .
Example:
Command: zoom;e;purge;all;*;n;la;m;MYLAYER;c;g;lt;hidden;;
Notes:
1. It should process commands and AutoLISP C: functions equally, so the macro
C:MYMACRO doesn't need to be called by (C:MYMACRO); and any of routine's prompts
can be handled inline as well, e,g, zoom;e;mymacro;yes;no;; etc.
2. It should know it's in a command line macro and use command-line versions of
the commands without requiring the '-' prefix (as shown with the purge command
above)
I've done this thru AutoLISP, but it should be built in.
B> A SHADEMODE system variable or even a simple ShadeMode property that will
report back the shaded condition of the current viewport. Unbelievably, this is
non-existent.
C> The ability to use multiple "mouse gestures" to input any command or macro.
Example, a click-drag-diagonal-swoop-up-to-the-right gesture would do a zoom
window from the lower left to upper right of the gesture. Likewise, a click drag
down-then-up gesture would do an UNDO or something. All wrapped up in a pretty
customization interface. Look at ARRIS for an example.
Matt
mstachoni@home.com
mstachoni@beyerdesign.com
