dmleves49
Message 1 of 11 (397 Views)
Custom Linetype - Shapes
397 Views, 10 Replies
07-26-2012 01:41 PM
Is it possible to create a linetype that just consists of the repeated shape? I'm trying to create railway tracks and my shape looks like this.
Shape
My linetype definition that ive tried is this:
*TRACK,Track
A,0.0001,-1.1622,[TRACK,Track.shx]
attempting to get a very small line, and then a space for my shape to fit into. This is what I get. Does anyone know the syntax to just include a repeating shape?
Dale
Line drawn using Linetype
dmleves49 wrote:
Sorry If I'm not understanding your reply, but the shape cannot be the first spec. That was one of the first thing i tried. The Space can't be the initial spec either.
No, but it can be the second one rather than the third -- my suggestion was to put it before the pen-up designator, not before the initial pen-down designator:
A,0.0001,[TRACK,Track.shx],-1.1622
dmleves49 wrote:
I tried it again and of course it worked nicely. Thank you very much it looks much better. Due to the limitations of AutoCAD and the way they included the shape functionality I do have this problem in polylines where there is a vertex. (Line to Arc transition.....
Make sure the PLINEGEN System Variable is set to 1 to enable generation of complex linetypes around/through Polyline vertices:
(setvar 'plinegen 1) ... or ... type PLINEGEN and answer 1 at the prompt
Or for Polylines already drawn, pick on them, and in the Properties box, in the Micellaneous category, set Linetype generation to Enabled.
Kent1Cooper
Message 2 of 11 (392 Views)
Re: Custom Linetype - Shapes
07-26-2012 02:33 PM in reply to: dmleves49
dmleves49 wrote:
Is it possible to create a linetype that just consists of the repeated shape? ....
*TRACK,Track
attempting to get a very small line, and then a space for my shape to fit into. .... Does anyone know the syntax to just include a repeating shape?
Given the way your shape must be defined relative to its starting point, put the shape insertion part before the pen-up [negative-number] designation, rather than after.  You can't entirely eliminate the short continuous-line parts at the ends -- the best you can do is adjust the overall length to minimize them.
Kent Cooper
dmleves49
Message 3 of 11 (380 Views)
07-26-2012 11:39 PM in reply to: Kent1Cooper
Kent1Cooper
Message 4 of 11 (365 Views)
07-27-2012 04:58 AM in reply to: dmleves49
Kent Cooper
Distinguished Contributor
dvertz
Message 5 of 11 (362 Views)
07-27-2012 05:29 AM in reply to: dmleves49
What a cool linetype.
However, I don't use linetypes that require SHX files. its just another thing that has to occompany your drawing when it shared. I have defined my linetypes to use the standard font. That way ALL users recieving my drawings can view them without the need of other files.
Here's my Vinyl Fence ... set your Standard Textstyle to Simplex with a 0.0 height for it to appear correctly.
*Fenceline_Vinyl,Fenceline Vinyl ____-____-____-____-____-___
A,0.250,-0.050,["|",STANDARD,S=0.0250,R=0.0,X=-0.050,Y=0.0083350],-0.0010,["_",STANDARD,S=0.10,R=0.0,X=-0.0510,Y=0.04770],0.0010,["|",STANDARD,S=0.0250,R=0.0,X=0.043250,Y=0.0083350],-0.044250,["_",STANDARD,S=0.10,R=0.0,X=-0.095250,Y=0.00952250],-0.0
For MY tracks ... I went in the field, took exact measurements and then created a dynamic block. Only drawback of a dynamic block (at least in version 2008), you can't make one to to work around an arc.
Autodesk Civil 3D 2014, Network, Carlson Software 2014, Build 121220
Windows 7 Pro, SP1 x64, AMD FirePro V4900 (FireGLV) (1920x1200)
Intel Core i7-3770 @ 3.4GHz, 8 GB RAM, 465GB WDC HD – 399GB free
dmleves49
Message 6 of 11 (350 Views)
07-27-2012 09:14 AM in reply to: dmleves49
Yes arcs are definitely a plus.:smileyhappy:
dmleves49
Message 7 of 11 (349 Views)
07-27-2012 09:19 AM in reply to: Kent1Cooper
That gives me a 'bad definition' error. Thanks for the suggestion though.
dvertz
Message 8 of 11 (346 Views)
07-27-2012 09:27 AM in reply to: dmleves49
Hmm. It works great for me. You didn't by chance place it on three lines in the LIN file. It must be only two lines.
Kent1Cooper
Message 9 of 11 (340 Views)
07-27-2012 10:40 AM in reply to: dmleves49
Well, I don't have any better ideas.  We have some that are defined just that way, and work well.
Kent Cooper
dmleves49
Message 10 of 11 (338 Views)
07-27-2012 10:58 AM in reply to: Kent1Cooper
