Here's a sample more specific to your question than anything in acad.pat:
*B-R-2,Modular Brick Running Bond Double-Line
0,0,0,4,2.666666,7.625,-.375
0,4,.375,4,2.666666,7.625,-.375
90,4,.375,2.666666,4,2.291666,-3.041666
90,3.625,.375,2.666666,4,2.291666,-3.041666
Besides, it's at real full size, instead of the truly stupid way AutoCAD
does what they deign to call "brick." (That is, you use it at a hatch scale
of one, instead of having to try to figure out what scale to make it be
right in any real architectural drawing.)
If you want to use that to see how to build them, you can go from there
easily enough. But I have a whole mess of them, in single-line versions for
smaller scales, and double-line versions for larger scales showing both
sides of the mortar joints (like this one). I've got standard modular
brick, jumbo, engineer, utility, CMU, 8" square CMU, and some other odds &
ends, in (for most of those) running bond, stack bond, basketweave,
herringbone, flemish bond, and section versions including the joints and the
typical diagonal hatching. I'd be glad to post them here, if people are
interested -- no charge.
Kent Cooper, AIA
"StanoV" wrote...
> I am trying to create a brick elevation hatch Mw/ mortar joints. I
understand that when i start i have an orgin point, an x & y delta offset, a
pen up or pen down length, but i can't get it to work. Is there a good step
by step tutorial out there? I have looked at the help files within AutoCAD &
it has got me started, but i am not following the procedure 100%
