Solved by hgasty1001. Go to Solution.
I'm not sure what do You mean with current .Net directory, if you need to know the framework in use by AutoCAD, you can read the acad.exe.config file, the .NET framework should be under %windir%\Microsoft.NET\Framework directory.
Gaston Nunez
