Visual LISP, AutoLISP and General Customization
CUIX load help in LISP
16 REPLIES 16
Message 1 of 17
RockyBrown4134
1948 Views, 16 Replies
I wrote the following code to load a menu and ribbon, based on the user login:
(defun c:SCSG_CMS (/ LGN)		;For Testing
(setq LGN (getvar "loginname"))
(if
   (or 	(= LGN "user1")		;List of the possible users
	(= LGN "user2")
	(= LGN "user3")
	(= LGN "user4")
	(= LGN "user5")
   );end or
	(progn
	   (command "netload" "clsCMS_ACAD.dll")
	   (command "menuload" "CMSaddonACADmenu.cuix")
	   (command "cuiload" "CMSaddonACADmenu.cuix")
	   (command "RIBBON")
	   (command "startDE")
	);end progn
);end if
);end defun
We have 40+ users but only a few need to load this menu. I want to keep it so all I have to do is update the list of users as the change.
When I run the routine, the ribbon loads, but the menu does not. I made sure the Support File Search Path was correct.
I added the two lines:
 I added either line  and both but I can not get it to load the Menu on the pulldown.
I must be missing something simple. I tried to search this group for loading .CUIX. Dind't find anything (or if I did it did not register in my mind.)
Any Suggetstions where I went wrong? Is there a better way to accomplish this? All comments and suggestions are welcome.
Thank you in advance.
If this response answers your question, Please mark this response as "Accept as Solution"
Rocky Brown
AutoCAD 2020 / Inventor 2020 / Plant 3D
16 REPLIES 16
Message 2 of 17
paullimapa
in reply to: RockyBrown4134
If your menu file: CMSaddonACADmenu.cuix has the following:
1. MENUGROUP name ie: CMSaddon
2. Has a pull down menu section defined as "***POP1"
Then you can use the following function to place that pull down menu:
(put-mnugrp "CMSaddon")
; Place the mnugrp pulldown 3 positions over to the left from the last pulldown menu
(defun put-mnugrp (mnugrp / n )
  (if (menugroup mnugrp)
      (progn
       (setq n 1)
       (while (< n 24) ; there are 24 pulldown menu positions
        (if (menucmd (strcat "P" (itoa n) ".1=?"))
            (setq n (+ n 1))
            (progn
             (if (> n 3)
                 (setq n (- n 2))
                 (setq n 3)
             );if
             (menucmd (strcat "p" (itoa n) "=+" mnugrp ".pop1"))
             (setq n 25)(princ)
             (princ(strcat"\nMenu Group [" mnugrp "] loaded."))(princ)
            );progn
        );if
       );while
      );progn
  );if
);defun put-mnugrp
Area Object Link | Dwg Setup | Feet-Inch Calculator | List on Steroids
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 3 of 17
RockyBrown4134
in reply to: paullimapa
     MENUGROUP name is CMS
        In the CUI, menu name is CMS, Aliases is CMSacad, Element ID is ID_CMSacad
Rocky Brown
Message 4 of 17
paullimapa
So if your menugroup name is CMS and as I mentioned in my previous posting you'll need to have a pull down menu defined as ***POP1, then all you have to do is run this command: (put-mnugrp "CMS") and your pulldown menu will show.  If you have toolbars defined in your menu using ***TOOLBARS and you have a toolbar labeled as CMSToolbar then you'll need to bring these out with the following format: _.-TOOLBAR "CMS.CMSToolbar" _Top 0,2
I'm not aware of a way to just bring out what you have defined under Aliases as CMSacad, & Element ID as ID_CMSacad
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 5 of 17
RockyBrown4134
Thanks. Heading out for the day. I will try this in the morning.
Rocky Brown
Message 6 of 17
paullimapa
So your cui file should have a Menu section similar to what's show in attache screen capture.
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 7 of 17
RockyBrown4134
Here is what it actually looks like.
Rocky Brown
Message 8 of 17
paullimapa
Then you could try this:
Either change the Aliases name from CMSacad to Pop1
or
try this revised code which requires you to provide your Aliases name CMSacad instead of the set name of Pop1:
(put-mnugrp "CMSaddon" "CMSacad")
(defun put-mnugrp (mnugrp popname / n )
      (progn
       (setq n 1)
            (setq n (+ n 1))
            (progn
             (if (> n 3)
                 (setq n (- n 2))
                 (setq n 3)
             );if
             (menucmd (strcat "p" (itoa n) "=+" mnugrp "." popname))
             (setq n 25)(princ)
            );progn
        );if
       );while
      );progn
  );if
);defun put-mnugrp
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 9 of 17
dgorsman
Don't forget about workspaces as well.  AutoCAD will attempt to load the last used workspace at startup which may or may not include the desired menu.
I've also run into problems with client-supplied menus in CUIx files, with the following results:
- doesn't work well with Enterprise-located workspaces; the workspace has to be in the Main
- auto-saving workspace settings makes a real hash out of auto-loading CUIx/UI elements
- after loading the CUIx as partial to the Main, and having the appropriate menu loaded, the active workspace has to be reloaded; setting the system variable is ignored as it ignores the duplicate workspace name, this has to be done from the icon at the lower right of the application window
- trying to dynamically load partial CUIx files can end up with them being loaded multiple times: once at start up (it remembers what was already present)
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
Message 10 of 17
RockyBrown4134
Don't really want to do this since this is a second party addon.
or
 Tried this several times(After exiting Autocad, Rebooting, combination of both).
Still only loads the Ribbon on my machine.
Rocky Brown
Message 11 of 17
RockyBrown4134
in reply to: dgorsman
                                         I agree.
                                         the workspace are in the Main CUI
                                             Auto-save is turned off
                                             Not sure I understand wich Icon. Can you post a picture?
                                            I agree.
Rocky Brown
Message 12 of 17
dgorsman
The active workspace is ticked (its also possible to have no active workspace under some circumstances).  Clicking the active workspace from the list will reload it, which is sometimes necessary to have the changes shown.
Message 13 of 17
paullimapa
Looks like the Alias must be named Pop1.
I created a sample CMSaddon.mns which I used Menuload to create the cuix.
Right away with Alias named as Pop1, the pull down showed up after Menuload:
(command"menuload""cmsaddon.cuix") or (command"menuload""c:/temp/cmsaddon.mns")
(put-mnugrp "CMSaddon" "Pop1")
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 14 of 17
RockyBrown4134
I just noticed, there are 23 pull down menus. Could that cause a problem?
Rocky Brown
Message 15 of 17
paullimapa
Doing a google search according to this link:
http://knowledge.autodesk.com/support/autocad/learn-explore/caas/CloudHelp/cloudhelp/2015/ENU/AutoCA...
Pull-Down Menu Aliases
Pull-down menus should have one alias in the range of POP1 through POP499. Menus with an alias of POP1 through POP16 are displayed on the menu bar by default when the customization (CUIx) file is loaded. All other menus must be added to a workspace to be displayed.
Exchange App Store
Paul Li
IT Specialist
@The Office
Message 16 of 17
RockyBrown4134
Thanks. I'll read tonight.
Rocky Brown
Message 17 of 17
RockyBrown4134
I read the posted link last night and got to thinking.
Could I look at this in a different way? Could I load the CMSaddon.cuix, then in the acadmain.cuix, just remove the menu from the workspaces that do not require the add on?
Just a thought.
Rocky Brown
”Boost
