Visual LISP, AutoLISP and General Customization
Creative Autolisp split view
29 REPLIES 29
Message 1 of 30
A.wikipedia
1167 Views, 29 Replies
Hi all.
I are use Autocad structure detaling 2013.
Please tutorial write lisp  split view same video.
http://www.youtube.com/watch?feature=endscreen&v=-krtEmc7UPs&NR=1
29 REPLIES 29
Message 2 of 30
A.wikipedia
in reply to: A.wikipedia
Please hlep me
Message 3 of 30
hgasty1001
Please post a description of your problem  in your native language.
Gaston Nunez
Message 4 of 30
A.wikipedia
HI. I'm vietnamme
You can  write lisp "split view" same video.
thanks.
Message 5 of 30
hgasty1001
Sorry I can't understand or guess what yo need. Try using Google translator from Vietnamese to English.
Gaston Nunez
Message 6 of 30
A.wikipedia
in reply to: hgasty1001
HI
Thanks you.
I am use Autocad 2013 detaling structure.
I want to write a lisp command "MVIEW". Like youtube video.
Message 7 of 30
devitg
Up load your dwg
Message 8 of 30
devitg
Or send it to the email at the attached file
Message 9 of 30
Gordon_S
You don't need a lisp to create the sectionalised and subsequently composite views.
In paperspace using the overall viewport from which you need to make your sectionalised set of views (having set it up using MVIEW) you COPY the viewport on top of itself the same number of times you need a diferent piece of the whole.
Then, you click/select on the viewport (only one - which will be the last copy) and then click on each of the appropriate corners to make the selection of the specific part of the underlying part of modelspace.
You repeat that with each of the other copies by ensuring that you select the next one by clicking away from the last adjusted viewport, on any of the remaining copies, creating a different viewport area with each one.
When you have all your viewports covering the sections of the modelspace that you require, you simply do what the video demonstrated by selecting them and moving to a new part of you paperspace and aligning them to suit what you wish to print/plot.
Hope this helps
Gordon
Message 10 of 30
A.wikipedia
in reply to: Gordon_S
Thanks you Gordon. I do not understand very much.
can you give me an example with video???
Message 11 of 30
Gordon_S
I can't do a video, but the attached drawing (Acad2004) shows the stages with simple notes that you could translate.
Gordon
Message 12 of 30
A.wikipedia
verry Good.
but do such is manually.
I am want to create 1 lisp for working it faster. you can help me make one lisp.????? Please
Thanks you Gordon
Message 13 of 30
A.wikipedia
Please help me.
Message 14 of 30
Gordon_S
Look, have you tried the manual method - it doesn't take that long once you have the base viewport set up.
A lisp will only save a few seconds each time you need to create 'sub-views' so unless you plan to use this several times every day, it is not even worth the time to write a lisp.
While you have been waiting for someone to write a lisp for you, you could have tried and used the manual method - it is not difficult.
Gordon
Message 15 of 30
A.wikipedia
THANK YOU.
I'll wait for your lisp.
Message 16 of 30
Gordon_S
You will be waiting a long time - no one is going to write a lisp for you, so don't thank me.
Message 17 of 30
greg_battin
This has been a funny thread to watch
Message 18 of 30
Gordon_S
in reply to: greg_battin
Quirky I suppose.
Not sure why I make the effort to try to help some people though - I'll just go and bang my head on the floor again.
Thank goodness it gave you a smile at least.
Message 19 of 30
A.wikipedia
But anyway thank you Gordon_S.
Can someone help me. Please help me?????????????
Message 20 of 30
devitg
USE MEASURE , NO FURTHER HELP NEEDED
”Boost
