Visual LISP, AutoLISP and General Customization
Creating linetype
2 REPLIES 2
147 Views, 2 Replies
Creating linetype
I was wondering one thing.Using Alisp, how can i do suvh an
linetype(attached file)?
M
2 REPLIES 2
I see,
It is part of lines and arcs.I should make one part of it and repeat it
certain time?right?
You should try using the batting linetype. If that doesn't suit, then, if you want a
linetype, you need to create the shape(s) you want to use, compile the shape file, and
then create a linetype from the shape(s).
I don't think there is any worthwhile lisp method to do all that. But after you have the
linetype, lisp can load it easily.
t"Martin" wrote in message news:5783168@discussion.autodesk.com...
M
”Boost
