HI There,
A tough one i just cant figure out.
I want to create a rectangle (survey windows on a house) by picking the survey points near the builing line. (See attached).
I want to select first point, then second. Then have the rectangle 0.1 wide. rectangle has be be perpendicular to points and to building.
Is this possible is lisp?
I have attached what I would like to see in lisp. DWG in 2007 format, I use 2014.
Thanks for any help its much appreciated.
Regards
Allan
Solved by marko_ribar. Go to Solution.
Hi Allan, try this code, it won't work for entities not parallel to WCS... Assuming you're using WCS by default...
(defun c:rect ( / ss p1 p2 w r1 r2 r3 r4 r31 r32 r41 r42 p ) (vl-load-com) (prompt "\nSelect LINE or POLYLINE") (while (or (not (setq ss (ssget "_+.:E:S" '((0 . "*POLYLINE,LINE")))) ) (not (vlax-curve-isplanar (ssname ss 0)) ) (not (or (equal (vlax-safearray->list (vlax-variant-value (vla-get-normal (vlax-ename->vla-object (ssname ss 0))))) '(0.0 0.0 1.0) 1e-8) (equal (vlax-safearray->list (vlax-variant-value (vla-get-normal (vlax-ename->vla-object (ssname ss 0))))) '(0.0 0.0 -1.0) 1e-8) ) ) ) (prompt "\nInvalid selection of polyline or line, or entity isn't planar, or entity isn't parallel to WCS") ) (while (not (setq p1 (getpoint "\nPick or specify first point : "))) (prompt "\nInvalid point specification, try again...") ) (while (not (setq p2 (getpoint "\nPick or specify second point : "))) (prompt "\nInvalid point specification, try again...") ) (initget 6) (setq w (getreal "\nSpecify width of rectangle <0.1> : ")) (if (null w) (setq w 0.1)) (setq r1 (vlax-curve-getclosestpointto (ssname ss 0) p1) r2 (vlax-curve-getclosestpointto (ssname ss 0) p2) r31 (polar r1 (+ (angle r1 r2) (* 0.5 pi)) w) r41 (polar r2 (+ (angle r1 r2) (* 0.5 pi)) w) r32 (polar r1 (- (angle r1 r2) (* 0.5 pi)) w) r42 (polar r2 (- (angle r1 r2) (* 0.5 pi)) w) ) (while (not (setq p (getpoint "\nPick side to place rectangle"))) (prompt "\nInvalid point specification, try again...") ) (if (< (distance p r31) (distance p r32)) (setq r3 r31 r4 r41) (setq r3 r32 r4 r42) ) (command "_.pline" "_non" r1 "_non" r3 "_non" r4 "_non" r2 "_C") (princ) )
M.R.
That prefix "_+.:E:S" is undocumented parameter of (ssget) function - in my documentation it says that this is used to imitate (entsel) function... Look for Selection Set handling page on www.lee-mac.com ... I think you should find this parameter (mode)... In addition to my previously posted code, I wrote one that will work in UCS rather than just WCS... So here is it - not much different, but I think better and more applicable...
(defun c:rect ( / ss p1 p2 w r1 r2 r3 r4 r31 r32 r41 r42 p ) (vl-load-com) (prompt "\nSelect LINE or POLYLINE") (while (or (not (setq ss (ssget "_+.:E:S" '((0 . "*POLYLINE,LINE")))) ) (not (vlax-curve-isplanar (ssname ss 0)) ) (not (cond ( (eq (cdr (assoc 0 (entget (ssname ss 0)))) "LINE") (and (equal (caddr (trans (vlax-curve-getstartpoint (ssname ss 0)) 0 1)) 0.0 1e-8) (equal (caddr (trans (vlax-curve-getendpoint (ssname ss 0)) 0 1)) 0.0 1e-8) ) ) ( (wcmatch (cdr (assoc 0 (entget (ssname ss 0)))) "*POLYLINE") (and (equal (caddr (trans (vlax-curve-getpointatparam (ssname ss 0) 0.0) 0 1)) 0.0 1e-8) (equal (caddr (trans (vlax-curve-getpointatparam (ssname ss 0) 1.0) 0 1)) 0.0 1e-8) (if (vlax-curve-getpointatparam (ssname ss 0) 2.0) (equal (caddr (trans (vlax-curve-getpointatparam (ssname ss 0) 2.0) 0 1)) 0.0 1e-8) t ) ) ) ) ) ) (prompt "\nInvalid selection of polyline or line, or entity isn't planar, or entity isn't parallel to UCS") ) (while (not (setq p1 (getpoint "\nPick or specify first point : "))) (prompt "\nInvalid point specification, try again...") ) (while (not (setq p2 (getpoint "\nPick or specify second point : "))) (prompt "\nInvalid point specification, try again...") ) (initget 6) (setq w (getreal "\nSpecify width of rectangle <0.1> : ")) (if (null w) (setq w 0.1)) (setq r1 (trans (vlax-curve-getclosestpointto (ssname ss 0) (trans p1 1 0)) 0 1) r2 (trans (vlax-curve-getclosestpointto (ssname ss 0) (trans p2 1 0)) 0 1) r31 (polar r1 (+ (angle r1 r2) (* 0.5 pi)) w) r41 (polar r2 (+ (angle r1 r2) (* 0.5 pi)) w) r32 (polar r1 (- (angle r1 r2) (* 0.5 pi)) w) r42 (polar r2 (- (angle r1 r2) (* 0.5 pi)) w) ) (while (not (setq p (getpoint "\nPick side to place rectangle"))) (prompt "\nInvalid point specification, try again...") ) (if (< (distance p r31) (distance p r32)) (setq r3 r31 r4 r41) (setq r3 r32 r4 r42) ) (command "_.pline" "_non" r1 "_non" r3 "_non" r4 "_non" r2 "_C") (princ) )
Regards, M.R.
