style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
<honkinberry> wrote in messageI
href="news:6095663@discussion.autodesk.com">news:6095663@discussion.autodesk.com...
would tend to think the easiest solution is to keep with the direction you
have been going. If all you really need to do is to scale a bitmap, there are
ActiveX libraries you can use to do so. And if you are operating off a local
server, you could use the PHP image manipulation functions to accomplish this
for free. Otherwise, I would think the thing to do would be to have the
program carry out all the activities that the user is indicating in the dialog
box -- then a quick click of a button hides the dialog, letting the user pan
and zoom around as desired in the layout, with a Right Click returning to the
dialog box, much like the hatch preview process. And yes, you could certainly
have all this occurring in a new layout that was created just for this
purpose. --J
href="news:6096137@discussion.autodesk.com">news:6096137@discussion.autodesk.com...
think at this point you better start explaining what it is that you're after.
🙂 Paperspace is just like holding a piece of paper above your modelspace --
the viewport is the rectangle you cut in the paper to view your modelspace,
and you can move the paper closer and farther away to "scale" the modelspace,
and you can rotate the view as well -- all the while, you are not changing
anything regarding the modelspace. --J
